Bench grinder -brand advice
Lou Krupnick
>Thanks all, I could use some advise re: bench grinders to go with the new Wolverine sharpening system that's on order. Are the advantages of something like a Delta 23-750 that significant over a $80-100 Craftsman, DeWalt, Delta, Wilton grinder? Recommendations & pans appreciated.
Lou
Re: Bench grinder -brand advice
Fog Tanner
>I don't remember what the model number is, but I have the 8" Delta grinder that weighs 100lbs. The one they are dropping in favor the cheaper one. I would not trade mine for 3 of the new ones, just not the same grinder from. This thing is rock solid and has no vibration due to the weight. It came with a 60 grit white wheel and a gray wheel, which I replaced with a 100 grit white. It has a light and real glass shields. A real tool room grinder and not your $29 wonder.
I have it setup for my Ellsworth gouge and scrapers.
That said, all my other sharpening is done on a Tormek - which I also wouldn't trade.
My $.06 worth (inflation)....
Fog
ThomD
>If you want to spend big bucks, get a KMG 2 x 72 grinder. For turnning tool sharpening I have been using a Grizzly style 1750 rpm x 8" grinder for over 20 years. Works great. I use sanders for much of what I used to use grinders for. They seem safer, faster, cooler, and cheaper. I still prefer grinders for scrapers, and slow profiling of edges.
What Fog said
TD
>I agree with Fog. Try to find a fixed speed, 1800 rpm Delta. Do NOT get the variable speed Delta. As Fog said, replace the 60 grit wheel with a quality 100 grit wheel and you have the last grinder you will ever need. If you want to spend a lot more bucks then get the Baldor. Do not get one with 3/4" wide wheels, one with thin side plates that look like washers, or one that does not have left-hand threads on the left side. Remember, this is one machine that should never have to be up-graded.
TD
Wood Craft sale
Dustmaker Mike
>they have their Slow Speed Gringer on sale though the weekend. I think it is less then $70.
Re: Wood Craft sale
Jennifer@Indy.USA
>I would be leery of the Woodcraft slow speed grinder. My experience was that I bought one at the $99.00 price and it was so out of balance that there was no way you could grind a turning gouge on it. I even put new wheels on it. I took it back...got another one off the shelf and the same thing. I was really bummed because our club had bought one that ran true and was real smooth. The guy working told me that Woodcraft had changed manufacturers from when they were the blue colored model...and that they had more than a few come back since they changed. They may be trying to unload these now at a deep discount.
I ended up buying a Delta and still didn't have great results until I got the Oneway wheel balancers. They are the ticket to a really smooth running grinder in the $100 price range. I keep saying one of these days I'll pony up for a Baldor.
Jennifer
Re: Wood Craft sale
Bruce McElhaney Spring Lake, MI
>Have a 6" 1750 RPM Baldor and a 8" low speed Delta grinder. The Baldor spins like a silky smooth top. The delta less so, but I use the Delta more often because of it's 8" round and 1" wide wheels. If I ever hit the lotto, I'll for sure get a 8" Baldor.
Mark Kauder, Phenix City, AL
>This last summer at the symposium in Kansas City, I bought a grinder from Klingspor for $90. I bought one for the club and a club member. They are very good. Smooth, quiet, and come with two white wheels.
Mark
Lou Krupnick
>Thanks to all for the insight!! Happy Thanksgiving
I got lucky!!
Dave Peebles Lyons, Ohio!
>Hi Jen,
I had heard these type of stories too about the Woodcraft grinders.
I had gleaned an edge on my tools for years with a slow speed 6" grinder I got from Garrett-Wade. But I really wanted the extra width of the wheels on the 8" grinder. 3/4 vs 1"
I decided to try one of the Woodcraft grinders. Since the manager of my local Woodcraft is a good friend of mine, I let him know that I would like to try out as many as it took to find a good one before I pulled out the plastic. :) He said.... no problem.
The first one ran true and smooth right out of the box. It was one of the newer white models, but it has served me well for the last couple of years. But I would encourage anyone thinking of buying one of these to do a test run before you buy one. I have heard that it is a real hit or miss process. But mine has been great.
Best wishes and hope you had a great Turkey Day!!
Dave
Re: I got lucky!!
Charles Bjorgen
>Dave -- I used to own that Garrett-Wade slow-speed grinder. I called Garrett-Wade about this issue and was told that they had sold a run of six-inch grinders that their manufacturer had mistakenly made with a shaft that would accept only 3/4-inch wheels. They replaced mine at no charge with the model that will take a one-inch wheel simply by removing an inside bushing on both spindles. Doing so centers a one-inch wheel inside the wheel housing. If you still have this unit, you might want to check first to see if your grinder has those bushings and if not, see if they're still honoring that condition.
>>I had gleaned an edge on my tools for years with a slow speed 6" grinder I got from Garrett-Wade. But I really wanted the extra width of the wheels on the 8" grinder. 3/4 vs 1"<<
Avoid the woodcraft slowspeed grinder
Devon Palmer
>All,
I hate such a negative post, but, both my father and I bought the woodcraft slowspeed grinders and could NEVER get them to run true. (even with a oneway stone dressing jig) I've also seen numerous other posts (even in the forum) regarding the same issues. Just too much vibration (wheel is round, does run true) - mostly from wheel hold down plates the don't seem to be ground correctly. You could probably remedy this with a oneway balancing system as it comes with its wheel securing plates, but, at that point, you lose the savings.
I'm suffering along with mine. Dad has replaced his with a variable speed delta (same one used by my club) both of which run as smooth as glass out of the box. I'll replace mine as soon as I pay off all the other "toys" LOL
For the record, I'm a satisfied woodcraft customer, and buy locally to support the shop owner. But, this is just one product I can't say good things about.
- Devon, Columbus Ohio
Thanks Charles
>I do still have that grinder. But it is about 10 years old. It still works great... at least the last time I used it. I will check it out tomorrow to see it is the same as yours.
Also, if you still see Steve T. Tell him I said hello. It seems like years since I have seen him post anywhere. But things sure have changed on the Rec.Crafts.Woodturning site over the years. I still read there once in a while. But the spammers have driven me off over the last couple of years. Man, that used to be a great place to hang out...
Best wishes,
Dave
