Christmas ornament
Curt Fuller
>African Mahogany inside out Christmas ornament. I used the spray minwax gloss polycrylic. Tried several coats but can't get away from the bumpy orange peel look.
Christmas ornament
Curt Fuller
Re: Christmas ornament
>Curt Nice job on the shape. Your bumpy problem is the grain raising. The Gloss Polycrylic is water based and it raises the grain. You can try raising the grain before you spray by applying some water, let it dry and then sand very lightly with 400 to 600 grit. You just want to sand off the nibs. Then when you apply the Poly it won't happen. Your only choice now would be to hand sand the raised grain and then spray another coat. That should solve your problem.
