Gluing collars
Carole in VA
>I am wondering if I ought to be using something other than CA when gluing collars to a vessel, especially when they are dissimilar woods. Is wood movement going to cause a problem. Should I be using the "flexible" CA?
Gluing collars
Carole in VA
Re: Gluing collars
Ted Okolichany
>Carole,
I use wood glue like Titebond to glue down the collars that I put on my hollow forms. This way you can move it around to get the way you want it to look.
Ted
Align the grain of the collar with the form
steve antonucci
>I CA glue the collars and finish afterward. Even when I forget, I still haven't had any issues.
Steve
Re: Gluing collars
Dale Cook
>Hi Carole. I've been using weldbond glue with good results. It dries clear,seems very strong,and have not had any failures. I was using ca or epoxy but I think they get to brittle and with any movement I had a couple that let loose and re-glued with weldbond.I also turn some alabaster with wood rims so I need something that will move a little.Good Luck!
Re: Gluing collars
Jennifer@Indy.USA
>Carole, I use to use CA but I had one pop off once and from then on changed to wood glue. No problems since.
Jen
