Birch and Watco Danish - what the Heck!
David Breth
>I've been working on a spalted white birch, double-bullseye bowl (a very small one), that I thought I would try to finish with Watco. I've had two sessions where I "kept it wet" for about forty minutes, then wiped off excess, and another session where I "kept it wet" for about 20 minutes, then wet sanded with 400 grit, making sure to spend lots of time on the end grain (bullseyes), then wiped it off.
So, how does it look?
Dead.
The are are areas of end grain and side grain that look darker for my efforts, but that is all. Some areas of end grain look almost untouched by oil. I'm thinking that my next step will be to put the bowl in a baggy filled with watco and let it sit and soak for....ever, to saturate this thing to death, and then probably wet sand it when it comes out. I guess I would leave it in the bag for a day. I'm guessing it would take one more "20 minute with wet sand" session to put a final coat on. Whattya think?
David B.
Re: Birch and Watco Danish - what the Heck!
Patience is the main ingredient
TD
>in an oil finish. Some woods take more coats than others and temp and humidity also affect it. Give it a few days to cure and then wet sand it with oil and 600 grit paper. Then wipe dry and let it cure a couple of days. If necessary repeat the process with 800 grit and so on. Eventually you will be rewarded for your efforts. I have had pieces that took 3 months. I consider 2 months normal.
TD
Re: Patience is the main ingredient
georgetroy
>I quit using Watco over 15 years ago and haven't regretted it sense. From that point on it has been a seal coat of Deft Clearwood finish and then Urethane oil or Minwax tung oil finish. After a few days I can wax and buff if desired. I don't like the bleed back of Watco, the smell, the taste, and darkness of finished product. GT
It's a Danish oil...
>...so it doesn't build worth a hoot. I prefer a thin varnish like Waterlox Original or General Seal-a-Cel. Wipe it on with your hands until it is fully extended over the surface and almost dry to the touch. A couple coats in a couple days should get you the sheen you're looking for. On particularly porous woods, I sometimes put on a coat of thin shellac or SealCoat while the piece is still on the lathe, then I sand it back to bare wood. The shellac remaining in the pores makes the first coat of varnish go on like glass.
Two ¢,
Ellis Walentine, Host
Bill Howatt
>How does your method work on a porous wood like butternut, etc or do you seal it first with shellac like Ellis? I hate it when some areas are like an infinite sponge.
Thanks,
Bill
