Whats the tang size for home made scraper
Tim Conlon
>Hi,
I just got a bar of steel for making some heavy bowl scrapers. The steel is 1.5 inch x 3/8 inch x 36 inch long, flat, oil quench, from enco ($40). If I cut it in four pieces 9" each, how much of that 9" should I give to the tang (part that sticks in the handle) and how much to the scraper? Was thinking: 6" blade and 3" tang should give enough support.
I dont have a commercial scraper so I cant see what the dimensions should be, has anybody taken one of them apart? any suggestions would help.
Thanks,
Tim
Re: Whats the tang size for home made scraper
Fred in NC
>Tim, 3" should be enough. Of course, that depends on the wood holding on to the tang. A ferrule usually reinforces the wood and is highly recommended.
Bob R
>Tim.. What or where is enco? I have been using real old files ground down for scrapers but would like somthing harder and thicker to use. (maybe safer to as files do snap.)
Here it is ...
Fred in NC
>www.use-enco.com
I weld mine to a piece of 5/8" round stock.
Phil Joines
Tang, what tang?
Bob Hackett
>I grind a different shape on either end and then slide a foam grip from an exercise machine over the end I`m not using at the time.
If you can`t find the right size foam grip then go down to the local hot rod shop(or marine supply) and just buy a foot of whatever size hose fits over it.Hey,it works for Oneway,Hosaluk,Kelton,etc.
Mainely,Bob
