Blue Pine Box
Blue Pine Box
Blue Pine Box
Fog Tanner
>I had never seen one in any of the books or at any of the symposiums, so I decided to see if I could make one (actually two). And I want to know if there was a reason I had never seen a segmented box. I know that someone else has made them before, I had just never seen one. The first two were made of Aromatic Cedar. After glueing up them up, they were a little larger than I had intended, so I went back and came up with some new numbers. This time I elected to use some Blue Pine I had left over from another project. I cut out two and made the first, I loved the look of the first so much I immediately went out and got another log. It was really the next day as I finsihed it around 2 in the morning.
I located some Blue Pine logs outside of Lake Jackson, Texas only 1/4 mile off the main road. But, I am sure that Blue Pine is located in other parts of the country. There were a number of 8 foot logs to pick through, but the only down side was they were all 1.5"x3.5" even though the Lowes sign clearly read 2"x4"x8'. At $2.36 I couldn't complain. That was enough for seven boxes and some spares.
The boxes are all endgrain like any other box. The top and bottom are cut from some "boards" I made by cutting pieces to length and glueing them together to form some "sticks" 26" long. The short segments were then cut endgrain up. That way I could turn the box as I normally do with a skew for the most part.
After making 9-10 of these I found out why Richard Raffan wil never make one. It takes me about 5-6 times longer than one from solid wood. There is a lot of cutting and glueing to get to the point of turning the box. And the tools dull a little quicker due to the glue. But, I think the look is well worth it. I am making some more right now that are all cedar, some that are all pine, some that are cedar and pine, and some that have well over 100 pieces in them. Over all they are a most fun project.
Fog
Re: Blue Pine Box
Re: Blue Pine Box
>Fog nice box. I like the way you worked with the grain on top. I made many boxes years ago from segmented wood. I had no idea how to work with green wood and couldn't find thick pieces of dry wood. I would glue up 4 foot sections of contrasting pieces so I could get 10 or 12 boxes from each glue up. Then I started making segmented bowls with lids that I called boxes. There are a lot of options. I will be making many boxes between now and February and will probably make some segmented boxes. I'll make some photos as I progress through the stages of designing new boxes that I've never done before.
Re: Blue Pine Box
Re: Blue Pine Box
Fog Tanner
>John,
I would be most interested in your pictures and your approach. The boxes I have been making are stave construction on the sides with solid segments for the top and bottom. This results in 24 pieces for each box, 12 for the side and 6 on the top and bottom. I am doing some more, similar but with variations for the top and bottom construction and a lot more pieces. As these are only 2 1/2" x 4", it gets to be fun adding more pieces.
Fog
Re: Blue Pine Box
Re: Blue Pine Box
>Fog My early ones were like yours. I probably had 20 yours in each box or bowl. Then I decided to do them in a production sequence and do long glue ups or cut 60 or 80 parts at once. That way I spent less time doing all the menial work. Still a hastle. Now I make smaller boxes that need to be hollowed. I'll show you some later, I'm going to start making boxes in the next week or so.
Re: Blue Pine Box
Re: Blue Pine Box
Kevin Gerstenecker
>I've never seen any boxes like your's either Fog. Great idea, and the results are awesome. The design possibilities are endless! I look forward to seeing more of this type of box. I have a decent stash of exotic woods that would be great candidates for this method.
Thanks for sharing your work!
