The Turners "other" bandsaw blade
Bud
>As a turner most of us have a main favorite bandsaw blade to cut green wood, give or take from a 3/8 3tpi.
What �other� blade do you use most often, OR wish you had for special stock or general use, other than the one you use for cutting thick green wood. Do you have a special blade for say, cutting thinner exotic pen and stopper blanks, or maybe a thin fine tooth blade for cutting plywood/mdf disks and such, or a resaw blade?. So as a turner, what is your other favorite bandsaw blade/s, or the one that you wish you had. Blade specs helpful.
Have a lot to be thankful for, have a safe holiday, and safe turning.
Bud in IL
Re: The Turners "other" bandsaw blade
T-wolf
>1/2" AS 3 tpi
But,
I NEVER use the bandsaw in connection with turning or on green wood.
Blanks are "rounded" with the chainsaw.
>Bud I buy a 1/4" blade with a fair amount of teeth. don't remember for sure what it is. I use it when I need to cut small things that would be dangerous with a 3 tooth blade. I also use it for cutting small bowl blanks.
Re: T-wolf
Wally Dickerman in Arizona
>Mark, I'm curious...why not use a bandsaw for rounding blanks? On most normal blanks I use my bandsaw for that purpose. All I need is one good flat surface.
Wally
Re: T-wolf
>Wally,
I don't feel it safe to use a bandsaw to round out wet wood blanks, plus much of the blanks I use are just too big to hold up and control on a saw table; I raise them for mounting between centers with a track mounted electric winch. Also, here in "wood-rich" sections of Western New Jersey where the average age of all trees is about 60 years, much of the harvested wood is from farms, field bounderies, and residential areas and is just as likely as not to contain varying amounts of iron. Ain't pretty hitting nails and such with a bandsaw blade.
I know others who use their band saws without reported incidents. I just don't.
I trim the points on the octogon with the chainsaw, and my lathe is heavy enough that I don't have trouble with balancing the weight with the initial cuts.
Mark
Fog Tanner
>Depends on which bandsaw. One the 14" Jet, I use a 1/4", 3/8"x6tpi and a 1/2"x3tpi T-Wolf. The 3/8" for dry stock and the 1/2" for green wood and some dry blanks. I use the 1/4" for scroll type work and don't remember the tpi.
On the 16" MiniMax I use 3/8", 1/2", 3/4" and 1" steel blades. I also have a 1" carbide blade. The 3/4" and 1" blades are for resawing. The carbide blade is only for really special wood, at $200 a blade it stays on the wall most of the time. I don't remember the tpi except for the 1/2" which is 3AS and I use it for cutting bowl blanks, I would have to look in the catalog for the others. All the steel blades are T-Wolf and the carbide is made by Olson.
Fog
Re: The Turners "other" bandsaw blade *LINK*
albertabob
>This stripped from the ad for the premium blades:
The are sharper in my mind and seem to out last the others I have used. (subjective of course.)
This premium blade was designed with the professional and serious woodworker in mind. It is truly a unique blade featuring many new advances in blade design. Made from the toughest alloys, the teeth are precision ground and razor sharp, not punched or milled like traditional blades. During the manufacture of this blade, the teeth are impregnated with Carbide particles which greatly improve the cutting life of the blade. The teeth also feature a new aggressive tooth design and set. The sides of the blade are polished smooth and the back of the blade is rounded to allow it to feed and turn with less heat and chatter. This blade is manufactured to the industry's highest standards. No less than 30 inspections and tests insure this is the best blade for the discriminating woodworker.
Bob
http://http://www.supercutbandsaw.com/
>Bob,
When you post a link with copy & paste, you must erase the "http:/" already in the box. Otherwise your link goes nowhere.
M
Greg Jensen
>Timber wolf makes a blades with more set in it for woodturners. I use the 1/2" wide becausethey are less likely to break at the weld. These blades with extra set work very well on green wood.
Re: T-wolf
George Van in WI
>I�m with Mark; I use the chainsaw for most all my blanks. With the sawbuck I can safely cut and trim. I have a little Stihl 021 that is handy at time with a 16� bar for small blanks. I found my bandsaw blades, the Timberwolf blades Greg Jensen describes, getting dull quickly from the bark. I could re-sharpen them a few times but the chain saw last a long time between sharpening and I can re-sharpen quickly when needed if I hit debris. A chain is only $14 and last a long time. For me chain sawing is faster and safer. The lathe and gouge makes the blank perfectly round.
