We value your privacy.
>I have a single unit dust collector, a Penn state model, and I want to put an adapter to the 4 in port and run a shop vac hose from it, to use on my hand tools, which accept a 2 1/2 hose....how well would this work?.....the dc is quieter than my Rigid shop vac, and I have seen a muffler for the shop vac at local Home Depot store, but not sure if it works or not, says will quiet vac by 25%, does anyone use the vac & muffler and does it work?...tks for any info..Dennis
"I have a single unit dust collector, a Penn state model, and I want to put an adapter to the 4 in port and run a shop vac hose from it, to use on my hand tools, which accept a 2 1/2 hose....how well would this work?.....the dc is quieter than my Rigid shop vac, and I have seen a muffler for the shop vac at local Home Depot store, but not sure if it works or not, says will quiet vac by 25%, does anyone use the vac & muffler and does it work?...tks for any info..Dennis"
The DC adaptors work quite well actually. I have adapters which go from a long 4" flex hose connected to my DC pipe run which I hook up to my bandsaw and another which I hook up to my router. The drawback is you need to come up with something to clamp to your bench (or whatever you are using to support your work) to support the hose. It gets to be a "drag" dragging the hose around. If you can pick up an articulated arm from an old "task lamp", you can use that to act as a hose support. I also use a floor stand suction head beside my work bench on occasion. One of these days I'll build myself a sanding table though.
>Dennis That's what I do. I had to make a special adaptor out of PVC. I ran a 2 1/4 Inch hose with adaptor from the 4. Then built my PVC adaptor to go from the 2 1/4 to the 1 1/2. I mounted it on my chuck and turned a slight taper on the inside to fit the two hoses.
>Woodcraft has numerous fittings that allow you to reduce from four inch to 2 1/2", I keep one sitting on top of my Performax. It was made back in the day before they put four inch connections. I keep another to use to hook my four inch DC hose to my shop vac hose. I even have one that drops it down to a smaller shop vac hose and the wand on that fits on my ROS, belt sander, and plate joiner. Also, like John, I have made a bunch of adaptations form PVC to metal duct to DC hose. Made a separator by putting a four inch duct Takeoff on the top of a trash can. The other side is a 4" DC connector. What can I say? It's what I had. I had two pieces of different four inch hose and just "screwed" them together. Just threaded one over the other. Go for it. Make it work for you.
