Hamlet hollowing system ???
Ed Moore
>Has anyone had experience with the Hamlet hollowing system? I would appreciate your comments.
Ed Moore
SW VA
Ed Moore
Ed Moore
SW VA
Re: Hamlet hollowing system ???
Keith Tompkins
>HI Ed, I have one of those systems.....It takes a while to get used to it. I find that angling the cutter head downward works well and helps avoid catches.Holding it level invites huge cathes.
With the shield set close to the cutting edge, it tends to clog the cutter. I slide the shield way back to avoid clogging, then hold the tool so the cutting edge faces downward, as described above. It's still controllable in that way.
Like all Hamlet tools I have experienced, it's a well made item.
Ed Moore
>Thanks, Keith.
I have also found Hamlet tools to be well-made. My interest in this system was raised when Jimmy Clewes recommended it at the OVWG Symposium last month. It turns out that there is a variation of the system with his name on it. Basically, he puts the small cutter on the big tool.
Which size cutter do you use? And is it hard or easy to sharpen?
Ed
