SURVEY: What is your coolest tip?
Gary Evans Tallassee, TN
>It occurs to me that we rarely see a spontaneous revelation of woodturning tips and tricks. They are usually posted in response to someone's question.
What tip or trick will you share? I'm looking for those where you went, "Wow, that's cool!" when you first discovered it. That's how I felt about the CA accel. tip that I just posted.
I even want the lurkers to come out of the closet on this one, if you please.
Thanks,
Gary
Re: SURVEY: What is your coolest tip?
Steven Antonucci
A few...
steve antonucci
>Super magnets stuck to the side of the cast iron legs on my Nova means I never need to search for the Chuck Key or allen keys for the chuck feet.
Turning the lock handles on my tailstock to the backside of the lathe means I never get jabbed in the side/leg while at the back of the lathe.
A long 1/2" bolt is way cheaper than an official "knock out rod", and the head keeps it from falling through headstock pin (swivelling headstock).
Steve
gimlets and spears *LINK*
JKJ in East TN
>1) A gimlet (link below) is perfect for making a small hole at the end of a very thin turning square for spindle turning, especially in hard or brittle wood that may otherwise split when you crank down on the tailstock. Much quicker to pick up and use than an electric drill. I have a small one stuck to the front of my lathe with a magnet.
2) I recently discovered that a very sharp pointed scraper is excellent for roughing unbalanced bowl blanks. This is sometimes referred to a spear-point scraper, shaped a bit like the prow of a speedboat. I saw this shape of tool used in a lathe duplicator, probably for a good reason. I ground one from an unused rounded scraper. Unlike using a bowl gouge (even working in from the ends as recommended) the spear point cuts effortlessly into the high points of the blank, including the end grain, without beating you to death. It works well even at a much lower speed than the bowl gouge prefers. I stab the point directly into the side of the rotating blank leaving a series of very rough groves and ridges. I continue to stab until I cut groves deep enough to touch all the way around the blank, then move to the bowl gouge to clean it up. I intend on posting a photo when I get time.
gimlets
Dick Hines
Re: A few...
Dick Hines
>Keep you fingers away from a chuck spinning at about 1500RPM. It makes short work of your fingers. Split my finger nail about half way up. Lost a bleeding and bad words. My wife told me to put super glue on to keep it from spilting more. I will not say what I told her.
Bert Smith
>Since it's close to Christmas, I have a holiday lighting tip. A couple of years ago my wife bought one of those cheap remote control plug in adaptors for our outside lights. The lights can be turned off and on with a little remote so that you don't have to go outside in the cold.
I confiscated it after we took the lights down and hooked up my dust collector to it. It works great! A cheap remote switch in a festive green color!
Bert
>I made a set of hooks to replace or augment the rubber bumpers on my Cole jaws. Just a 1" steel strap from the big blue box cut into eight pieces and bent up past ninety degrees, dipped in the rubber stuff for tool handles with a hole in them for the screw. The holes has to be accurately placed a given distance from the end, but I did that with a little stop block on the drill press. They extend the reach of the Cole jaws and hole much better than the rubber bumpers. Best thing I have done for the Cole Jaws. I use the rubber bumpers to hold them on.
I filed a notch in the Shaft lock/index knob on my lathe so that I can feel where the knob is as I rotate it looking for the "lock" position. Don't have to look, just touch it.
Bought an extension for the tail stock. Its a rod that has a female Morse taper on one end and a male on the other. About eight inches Long. I can put the live center in it and mount them in the tail stock and Press a bowl into the chuck or whatever and have the tail stock back out of the way.
I put a piece of masking tape on the side of the ways of my lathe. With a square I mark the "face" of the chuck jaws. Then I square down the rim of the bowl. Now I know that if there is say four inches between them and rim is 3/8" thick, I want that bowl to be about 3 1/2 to 3 5/8" deep.
Another trick I have used is to set the tail stock flush with the end of the ways. I have a short bed, you may have to set it at a "known" position. Then measure the distance between the face of the quill and the face of the chuck. Cut a stick that is say 3/8 short of that and then you can can just touch it to the bottom of your bowl and see how much further you have to go, or how much too far you have gone.
Sanding tip
tek-Brunswick, Ohio
>I have the Sears version of the Sanding Mouse. (I think Black and Decker make it for them.) I put the bottom on the sander that has the extension for detail sanding. I use it to sand areas that are hard to power sand other ways. (Like right up to beads or recesses) I think the sanding scratches are less apparent than most power sanding methods and I can sand right up to details. It uses hook and loop paper, sometimes I cut it to fit and sometimes I just stick on a 2� disk.
Carole in VA
>Most of you probably alrady know this. That blue painter's tape is great stuff. I use it to wrap my "cone" chucks that I use to reverse chuck hollow forms. It prevents the piece from slipping/spinning on the chuck, even with very light tailstock pressure, and protects the wood. I also wrap it around pieces to keep the wheels on my bowl steady from burnishing or marking the wood. It leves no residue. I also use it as a "reminder tag". If I have to leave a between-centers piece in progress, I usually release the pressure on the tailstock. I slap a small piece of tape on the piece and when I come back later, it reminds me to re-tighten the tailstock. Don't ask me why I started doing this! LOL
Barbara Gill, Remlik VA
>I don't remember if the using WD-40 thread was here or on WOW. Instead of spraying with a pump bottle I keep a blue paper shop towel slightly moist. I use it to highlight the sanding scratches, wipe between grits and lubricate the surface while sanding. My finished product has improved greatly. I found that spraying was putting too much on the wood plus I was wasting it.
RussFairfield
>Kerosene is a lot cheaper than WD-40 and does the same thing.
Cool...Thanks Russ!
Re: A few...
>Super glue sounds like a good idea. I know it produces heat but I have never had a problem with using it on small cuts.
Bob Hackett
>A strip of velcro along the ways to keep those sanding discs handy and in order.
A power strip bolted to the leg of the lathe for power to lights,drill and other accessories.
A bright light(I have a 300 watt halogen)bolted to the rafters over the headstock to see the profile and details better and to warm me up in winter.
Horse stall mats to save my back(thanks Mac)
A footswitch to shut the lathe off when things get scary or when teaching(thanks Jacques)
A hole with a nickel in the bottom drilled into the(chest high) base for the grinder to set the length for gouges when using the vari-grind jig.(thanks Bill for both raising the grinder and the nickel hole)
Using a de-burring wheel(like compacted scotchbrite) on an old bench grinder to smooth and polish all the non cutting edges on my tools.
Mainely,Bob
Re: SURVEY: What is your coolest tip? Why a nickel
Stuart Johnson
>"A hole with a nickel in the bottom drilled into the(chest high) base for the grinder to set the length for gouges when using the vari-grind jig.(thanks Bill for both raising the grinder and the nickel hole)"
I understand the hole but why the nickel?
Brian Hahn in SW Wisconsin
>It keeps the sharp tip of your gouge from drilling a deeper hole in the wood.
