Flatware Revisited Pic
Larry Guthrie
>I posted a few weeks ago about rehandling forks, knives, spoons, etc. I finally broke down and bought a set from Wally World. This is the prototype. I left the ferrule off...it was plastic. Portions of the drilled hole were filled with epoxy and sawdust (nearly invisible repair) to hold the spoon in. I have been using the spoon. So far so good. Any comments, critiques, or questions will be appreciated.
Re: Flatware Revisited Pic
oldgriz
>Very nice... I love the idea... my only problem is that my wife will end up throwing them into the dishwasher and destroying the finish, no matter what I tell her... LOL...
Either that or they will get tossed into the sink and get beaten by whatever else is in there...
Absolutley no respect for artistic work.... LOL
Steven Antonucci
That's nice!
steve antonucci
>Like the turning a lot. However, it looks like a really "cheap" spoon (like you'd get in a cafeteria). Could you buy a better piece of flatware and grind a tang? Sounds like a lot of work, but I'd bet it will look 1000% better in the end, plus you'll have a better weight in the hand.
I may have to give this a shot. I've made knives, but never flatwear.
Dishwasher Proof?
Garrett in Victoria
>For most people, that's a fundamental criterion for flatware.
Kudos for imagination. However, as to design, I think you will be hard-pressed to come up with a turned handle that will reflect the effort you are putting into this project. It's called flatware for a reason.
Cheers, Garrett
Re: That's nice!
Larry Guthrie
>Yep...the original spoon is from Wally World (Wal-Mart). It is stainless steel and fairly sturdy. I would be hesitant to spend a lot of cash on higher end flatware to destroy. There is a site that sells just the pieces and ferrules for about the same price I paid for the set. I guess it is 6 of one half dozen of the other. Thanks for looking.
Re: Dishwasher Proof?
Larry Guthrie
>I wouldn't know how to make it dishwasher proof. If anyone knows...please let me know!!!! As for the design to effort ratio...that is why I am doing it. I just think wood handles are a little more elegant. Thanks for looking!!
Don Henthorn
>Years before most on this forum were born, celuloid handles on flatware were popular for a while. My Mom had a set she just loved. Tnen one day she put the set metal ends down in a pot of water on the gas stove to sterilize them. The heat from the gas burner was too much and they started melting and then caught fire and that was the end of that. It happened at Christmas time and after christmas we had the tree to get rid of. I was turning small items back then on a really cheap little lathe with no chuck. I would drill a hole in the end of the blank and drive in a square headed 1/4" bolt for a drive. The threaded end of the bolt was held in the headstock with a drill chuck. Decided to use the cedar trunk of the tree to make handles for the flatware remains. They came out surprisingly well and the cedar really looked good with a wax finish. Mom used that flatware for several years before they started to deteriorate because of the washing.
Larry Guthrie
>That is what I like to hear. I want to make something that someone will use for years. Hope you have upgraded your lathe!!!!
Kurt Aebi
>Larry,
Don't worry about wether or not Don H. upgraded his lathe. Just look at some of his work and you'll see that he has and is quite goot at turning.
Good work on the spoon, it looks rather nice.
As for use - if these are to be meant for everyday use - I'd go with White Oak due to its hardness and good resistance to moisture. If used everyday - you want strength and durability. Use a high quality epoxy that will not breakdown with detergents. I use Emerson & Cuming's "Eccobond 286" epoxy. I'm not sure where to get it - I have a box ordered when my company gets a new batch. We use it for gluing ceramics that are cleaned in an ultrasonic bath with simple green and it holds up well. It is white, so coloring with sawdust works well.
If you want these to be for "Special Occaisions" then any wood selection would be fine and of course fancier turning design would be appropriate. Don't get too hung up on dishwasher proofing for this purpose. Remember that a lot of people use fine silver for these occaisions and put them away in a box most of the year. Your idea may work well as a display in a hutch for most of the year along with the fine china.
I think you may be on to something for a niche market.
Good luck.
Larry Guthrie
>You may be right about the niche market...that thought crossed my mind.
