REAL MILK PAINT
Green wood tips?
Green wood tips?
Green wood tips?
Dave Thompson - Champaign IL
>I don't have much successful experience working with green wood, and was hoping someone could share some tips. If this is an FAQ, my appologies... I am new to this forum.
My father in-law just gave me a ~2.5" diamter "trunk" of a Lilac bush that best guess is 60 years old. It has some of the smallest growth rings I've ever seen that are occsionally purple/lavender. He also brought some sugar plum and white birch to play with. All are green wood. Anyway, I'd like to turn some of this and avoid having it crack due to drying like I've had in the past.
In my most recent experience, I stripped the bark off a small diameter log just because the bark was infested with bugs. Within a week it had some deep checks along the length of the wood. Another time, I just turned a 1" diameter piece from a 2" diameter branch, and within a week or so had a huge check along the length.
I presume the checks are due to the outside drying much quicker than the inside. How do you deal with this? I picked up some wood sealer (a liquid wax substance). I haven't used it for this because I've been concerned that the sealer would prevent it from drying, when I'd really prefer it to dry slowly without checking.
So,
  1. Is the problem that I am using the full growth ring radius in small diameter wood for my turnings, or is it a matter of how I allow the turned wood to dry afterwards?
  2. How do you deal with green live bug infested wood (like powder post beetles) for usage and/or storage? Do you strip the bark off? Put a large tarp around the area to catch them? Not worry about it? Work in a steel shed with a cement floor? Or find a different piece of wood?
Thanks for your time,
Dave
Re: Green wood tips?
Norm Smith in Nova Scotia
>Hi Dave,
Sealing the ends of your wood will slow the drying process and keep them from checking until you get around to turning the piece. However, I have found that lilac will split in a spiral the length of the wood. Last fall,I found quite a bit of lilac in a landscapers dump site. I took it home , sealed the ends and put it in an out building. Within a weel some of had split the length of the piece. I than took it to a friend who loaded in his kiln for the winter. This saved about half of the wood. Lilac is beautiful to work with and is a very beautiful wood. Nice goblets, vases, wine stoppers, etc. I don`t know about plum, but the birch will be OK by sealing the ends. It is difficult to dry and or turn wood with the pith in it. Others can probably do a better job at explaining this , than I. Anyway, good luck and don`t get discouraged when turning wood with the pith in as you will lose some.
Norm
georgetroy
>This is not an attempt to answer your questions. This is what I do. I turn my limbs and logs green. End grain is between centers. Small limbs make great looking vases. No faceplates. I use a Talon chuck or others after a rebate is made. I can make a closed form or open. After I have turned my shape and hollowed out, the project is mounted on a wood mandel and the bottom is turned down to a chisel point and nubbin is carved off. You will super glue your piths. There might be knot holes on the side those are super glue. Superglueing is after I have put on a Deft Clear Wood Sealer. I turn thin approx. 1/8" more or less. I watch the vases daily and use thin Super glue if I see any signs of cracking. Some cracks are filled with sawdust and super glue others with Coran and Super glue. Some of the wood vases will wrap more than others, so what. I have shown these before, but here is again a stack of vases which will be further enchance by carving, burning and or painting. Your lilac will best be left natural. Drying may take a month, just watch it and apply more finish and super glue as needed. My finishing process is simple. Deft Clear Wood finish(cutback about 10%) , then sand or abrade. Follow with several coats of MinWax Tung Oil. No Watco. Showing another shot of Diamonds in the rough, some need further sanding and processing.
Green wood between centers before
georgetroy
>As a followup, showing a small branch of hackberry between centers. Bark is on so is my face mask and golf gloove on left hands. Pounded that tailstock in and cranked it down tight. You can see shere I cut a side branch off. GT
Re: Green wood between centers after
georgetroy
>Wood is now shaped on the outside. Lacquer applied before super gluing the knots. Pith in bottom will have super glue. Top is at an angle that just enchances the shape. Wood is still wet, but not where you take a bath. GT
Re: Green wood tips? *LINK*
JKJ in East TN
>Dave,
Due to the nature of wood, for most species it is difficult to dry a branch containing the pith without the wood cracking. The wood shrinks more tangentially than radially and the resultant stresses are relieved by the cracks. It is more likely to survive if you turn it green.
I found the book Turning Green Wood excellent for ideas on how to handle green wood like this. The author turns many things from small diameter branches that contain the pith and indicates it is important to keep them wet until turned thin. He even sprays with water while working. Once the piece is very thin, it has a chance of drying without cracking. It will, of course, probably warp significantly, but that can add to the beauty of the piece like a tall goblet. Note that with something like a goblet, the pith should be off to the side and not embedded in the thin stem.
It is recommended to heat the wood to the center to kill the bugs, 130 degrees F for powder post beetles. Unfortunately, heating will accelerate the drying and the cracking. A tarp will not help. Some people have used insecides, but I can't see how they can work on bugs already in the center of the wood. Much may depend on the kind of bug. I think PPB prefer end grain, so if these are in the bark they may be another type and may be treatable with insecticides.
There is a lot of info on the web about identifying and treating critters in wood. For example, the knowledgebase on the WoodWeb site below may be useful. I once searched with Google and found more useful information than I could possibly read.
http://www.woodweb.com
Brad Vietje
Brad Vietje
>Dave,
Welcome to the addiction !
Turning green wood can be fun as well as frustrating. I agree with JKJ that Michael O'Donnell's book: Turning Green Wood, is excellent, and will answer all your questions, as well as anticipate others.
Some wood species are hard to dry, while some never crack. Lilac is one of the most beautiful woods of North America, and also one of the most difficult to dry successfully. It also smells beautiful when turned. You will probably have the best results splitting the little log segments right down the middle (pith) at an angle that keeps the pith near the center of the cut. That means that if the pith is well off center (as it will be if the trunk leans), you'll get one small part, and one larger part, with the pith near the center of the cut face. Alternatively, split it into quarters, for small spindle pieces.
Turning "on the pith", with the pith running right down the cebter, and the bark on the outside, isn't an easy chore for a beginner. To do this, you'll need to turn the object very thin, say 1/8" or so, and dry it slowly -- a common way is to put the turning in a paper bag or two, and check it weekly. if you're a beginner, you may want to do this a few months down the road.
For most woods, sealing the cut ends with Anchorseal is sufficient (along with keeping the wood away from sunlight, heat, breezes, dry air, etc...), but with a few woods like Lilac, Apple, and some other fruitwoods, seal all bare wood surfaces. Anchorseal will not stop the drying process -- just slow it down, which is just what you want.
Once the Lilac wood is sealed, keep it in a cool place, and while it is drying, look up a copy of "Turning Green Wood", and practice on some wood that's easier to dry, like Mesquite, Black Walnut, Butternut, Catalpa, etc... By the time you get pretty good at turning small things from green wood, as well as sealing and storing the chunks for use later, your Lilac will be ready for your new skills, and you'll have better results.
Safe Spinning,
Brad Vietje
Thetford, VT
Vicmarc.fan
>George,
I am curious, what do you do with your pieces with the superglued cracks? This is the first thing my wife looks for and says" you can't sell that, it has cracks in it and no one will buy it".
Ron
Re: Green wood tips? - Thanks
>Thanks for taking the time to respond. I suppose I'll focus on getting rid of the pith, or else plan for smaller pieces that do not cross the pith.
Dave
