bench grinders and wheel sizes ?
Dave Whiting
>What are the reccomended brands and what r the differences between 6,7, and 8 in wheels. Should u buy 3/4 or 1 in wheel thichness ?
Dave Whiting
Re: bench grinders and wheel sizes ?
TD
>I prefer the 8" grinder with the 1" wide wheels. It is much easier to keep the tool on the wheel with the 1" wide wheel; especially with the bigger tools. The 6" wheels quickly become 5" diameter due to a small amount of wear and that gives an excessive hollow grind (concave) tool. Delta made an 1800 rpm 8" grinder and there are some of these still available I think but they are trying to switch buyers to their newer variable speed model which is junk compared to the one they are discontinuing. I sold my last 1800 rpm Delta today and I don't know if I can still get them or not but it is the best grinder for the money that you will find. Baldor makes a very good one but at twice the price. The rest of them out there are hit and miss, one good one and the next one is bad. The 7" is a bit of an odd size and you will have a bit more difficulty finding wheels for it. I do not know of anyone making the 7" except Baldor. As far as rpm is concerned, most people prefer the 1800 rpm. If you go to the 3450 rpm then it becomes very important to have the wheels perfectly balanced. Buy the best grinder you can afford because it will be with you for many years; you will not outgrow it like the lathe.
Dave Shombert
>Dave,
TD pretty much said it all, but I'll add my endorsement for the Baldor 7" grinder. It comes with 1" wheels, which is a BIG improvement over 3/4" wheels, and, yeah, it's a lot more than a Delta but it's a Baldor. Very smooth, very quiet, lasts forever. You'll want to get a couple of good white wheels to replace the gray ones that come with it, or maybe you can find a place that sells it with white wheels.
If there are used machinery places near you, check for a used one. Even one that looks like it's had a hard life will probably still run as smoothly as when it was new.
Hope this helps,
Dave Shombert
Elkins, WV
JimQ
>Don't you mean Baldor 8"? I wouldn't wish a 7" grinder on anybody who would use it seriously. 7" wheels are hard to find, and usually not in the cooler grinding materials.
JimQ
Charles Bjorgen
>I have the seven-inch Baldor 1800rpm grinder and, while I'll admit wheels of that size are not as readily available locally or in catalogs, I've bought them from Woodworkers Supply, Packard Woodworks and Garrett-Wade Woodworking. There's quite a difference in price between Baldor's seven and eight-inch units, as I recall. My grinder is a wonderfully smooth machine though.
Phil Smith
>7 in wheels are readily available and in a broad range of material and hardness. 7" is a common size for surface grinders in the metal working industry so there is a broad range of materials, width and hardness readily available. Look at Enco, Travers and others for supply. A quick check for wheel availabity in Enco found more 1" wide wheels in the 7" size than the 8" size.
Dave Shombert
>Jim,
Um,... no, I meant 7 inch. I've been using it since 1998. I've seem wheels at several source, and I've bought them from Packard and now Oneway. It cost about half of what the Baldor 8" grinder cost and, as I said in my post, I'm quite happy with it.
It works for me. I guess it'd be a dull world if we all did things the same way.
Dave Shombert
