My Lathe, She No Go! :-(
Barbara Gill, Remlik VA
>I stopped my Oneway 1640 to put my Jacobs chuck into the tailstock and it won't turn back on. I got the little book out and then turned off the circuit breaker for about 60 sec.; still no go. The dust system runs so I have 220.
Dan will bring his tester to the shop after the Va Tech- UVA game. Darn football.
Who else has had this happen?
Re: My Lathe, She No Go! :-(
Carole in VA
>Uh oh...someone is not a happy camper. :( Isn't it irritating that nothing, absolutely NOTHING, can be allowed to interfer with a football game? I am assuming you powered the lathe down completely for a bit then tried again?
Rick Allen
>Call Kevin, he will make sure you are working very soon.
A simular thing happened to me a month or so ago. Kevin indicated that the most likely cause was a bad switch. As it turned out the problem was that I hads droped the remote on off a week before. The bezel around the stop switch took the hit which caused the stop switch to bind. When I pryed the stop switch out the lathe started just find. I dressed up the damage to the switch so that the stop switch moved freely and everything has been fine.
I am not saying that you damaged the switch. But the most likely cause of your problem is a failed switch.
You can open up your switch box to access the back of the on switch. Use a short (2") piece if wire to bridge the conections on the stop switch to test that the swich is the problem.
Good luck
Richard
>It really didn't matter Carole. I was pretty sure the electricity was ok since the freezer (3-phase) was running and my 220 dust system was running. In his defense, if I has stopped breathing or was bleeding to death I am sure he would have come to help. LOL
>Thanks Richard. There is an error message in the electronics box - EF6. I have posted on the Oneway Forum. I will call first thing Monday if I haven't had a response. All of my dealings with the Oneway folks have been very good.
>You are right Barbara is not happy! Yes, I did cut all power at the breaker box and tried again after 60 sec.
And of course it is Saturday....
JimQ
>Isn't it always the case? Friday night or Saturday is when everything happends, and you can't reach help until Monday. Frustrating.
JimQ
Dick Hines
Dick Hines
>EF6? I think that means to buy a Powermatic.LOL
e
>think that's just the indicator that the emergency button had been activated ... kevin walked me through this a while back ...
Peter Teubel
>Did you look up the error in the VFD manual? If you didn't get a book on the controller, you should have gotten a CD with the manuals on it.
>No, I didn't get either.
Of Course.
The Wood Spinner / Bill Hale
>Barbara
Not sure what your lathe has but on the 2436 there is a micro sw on the motor area cover plate. It can losen and cause a failure like you describe. Also are you sure the panic stop button is in the "on" position and that you did not accidently touch it.
Is the green light on in the sw. box ?
Bill in Casa Grande, AZ.
Get one...
Peter Teubel
>Ask Oneway to send you them. I'm surprised they didn't include it with the lathe. It was a wealth of information in addition to a listing of all the error codes.
gary s clarke
>My oneway 1224 also stopped working and the co said I should try a new switch. I ordeered one 2 wks ago and still haven't received it yet, maybe it is coming via pony express. Do you call that good service? :(
I Will, Thanks
Thanks, I Will Double Check
What I would Call It Is
>possibly jumping to an incorrect conclusion. Have you called Oneway to check? By now I would think that would be in order. There could be any number of explanations.
Re: What I would Call It Is
Mac
>Barbara,I'm not sure if the 16/40 has a reset button inside the control box or not, you might want to look for a red button inside the box. Sometimes they have to set unpowered for a few minutes before they will reboot.We have a dozen of them at the school,but have only once had one that would not reboot itself.
Re: Unpowered
>Would mean that the controller would have to be disconnected. Have you tried unplugging the units for about 15 minutes?
Re: "Reset" button????
RussFairfield
>Barbara,
Look inside the controller cabinet, and you will see several buttons. One of them will be labeled "RESET". Push it and see if that doesn't solve the problem.
Sometimes the controller will trip from running too slow too long, and sometimes it will just decide to trip for no apparent reason. This is an electronic device, and sometimes it will have a mind of its own. When this happens, there is no amount of waiting that will make it "reset" by itself.
If it is recurring problem, then there may be some need for re-programing, and for that you will need either the manual that came with the controller or call Oneway. If you call them, have access to the controller and the telephone at the same time.
Don't get upset with Oneway. All other lathes with electronic controllers have similar problems. It is the price we pay for technology.
As for delays in shipping, Oneway sends stuff over the border once a week. It used to be on Tuesdays. The 1 shippment is to avoid excessive duty charges. Depending on when the order was placed, it may take a week to get across the border. You might be able to avoid the delay if you request, and are willing to pay for, the express shipping.
My Lathe, She Go Now :-)
>Well, my face is red! Apparently I must have bumped the emergency stop button. I did fool with it after the lathe would not go but apparently not in the place in the whole process.
After getting back from church I went up to the shop, found the button needed to be reset and then powered the lathe back up.
Thanks for all the help!
>Thanks Russ. I never was upset with Oneway. I felt sure that what ever was wrong would get right. I am a walking cheering section for Oneway.
I didn't see a reset button when I checked the box. I also had read the book about the low speed thing and knew that that was not the issue.
>Mac, you are right, there does not seem to be a reset button.
Mark, I did repower after opening the circuit breaker. See explanation below. :-)
Re: My Lathe, She Go Now :-)
TD
>Sure pays to go to church doesn't it? :)
