We value your privacy.
>How in the world do you get your pics to be small enough to send to the forum? I took the pics on my digital camera and used 1m pixals (or whatever measurement the m stands for). I can't get one pic to even come across much less multiple pics.......I Wanta' show off my first turnings...........HELP ME I've fallen into the shavings and I can't get up. ;-)
>Jill, one of the easiest ways is to use PIXresizer software. The best part is it's FREE. Just download it on your system, and it will make short and simple work of resizing pictures you can post on the internet. I have been using it for about 3 or 4 years, and it works like a charm. Here is a link where you can download it for free!
>OK my first attempt at turning a lidded box. The height is about the size of a quarter. I am very into Asian design so.........give me your thoughts.....be tough I gotta learn. Thanks
>Jill Sorry I couldn't help you earlier I've been maning a studio tour all day. I see kevin took care of the size thing. The fuzzy picture seems to be either camera shake or incorrect focus. If you have a tripod use that or some other way to keep the camera from moving. You are obviously using some sort of tungsten or halogen lighting and this requires longer shutter speeds. Long shutter speeds mean camera shake because us humans simple can't hold a camera steady for a 1/4 second exposure or whatever it was.
It could also be focus. Sometimes the camera won't focus as close as we like. An out of focus photo just won't get sharp no matter you do. If your camera has a focus lock try focusing on the subject and then push the focus lock button (which is usually the shutter button). If you camera won't focus close enough simply back further away until it will get in focus. Then you can crop the photo before posting so the box will be as big as you want. If you find it necessary to do this you may end up using a higher megapixel setting on your camera so that when the image is cropped you will have a big enough file to make the box appear sharp.
The photo is orange. This means you used some sort of quartz or tungsten household light and had the camera set to either Auto white balance or daylight white balance. If your camera has a tungsten white balance setting us that instead and you will get better colors.
Nice box by the way, hope I get to see the details better.
>Try cropping the photo and eliminating most of the background so the photo that remains is all wood stuff. This will not help if the blur is from shaking the camera but might help if the resizing was done too late. First crop, then resize, then adjust other stuff. Mike's tutorial is awesome.
>Thanks John.......wow so much to know. I used my digital camera and made a photo tent with a shower curtain, chair and a shop light. I will change out the bulb. I used a natural light 75w. I will place the camera on a book (my tripod is too tall for this) and try again. And..........I thought the turning was the hard part. '-)
>Jill, the blur is in the photo itself, it has nothing to do with the resizing using PIZresizer. As Mike suggested, take a look at his photo tutorial, you will find some great tips and suggestions there. Just make sure you check the "maintain aspect ratio" box at the bottom of the photo size choice menu in the program. This ensures that the correct proportions of the piece are maintained after the resizing. Other than that, what the others have suggested would be things to try. Good luck Jill...........at least you figured out the posting......now, ya just need to tweak things a bit.
>Another tip. Croping out the cluttered background reduces the file size. Using a smooth background rather than a wrinkled cloth will not only make the photo look better but will also reduce the file size. I don't think we've ever touched on this but textured backgrounds (whether they look good or not) give you a larger file size than smooth backgrounds. Has something to do with compression but I'm not a computer person I just know from practice.
