ADVERTISE HERE - FREE TRIAL
Vacuum Pump Volume Question
Clem Wixted
>Would a vacuum pump that is designed for drawing a vacuum on air conditioning systems be compatible with woodworking use?
These units seem small but can pull over 29 inches of mercury (specs say 29.9 inches!).
The small part (of the pump, maybe 1/8 hp) is my concern or is vacuum more inportant than volume?
Clem
Re: Vacuum Pump Volume Question
Rick Allen
>That pump will work. 1/8 hp will be slow to draw down a vacumn and it will not be able to respond to a small air leak. The pump is only part of the outfit. You need plumbing, a guage and some drum chucks and plates chucks. If you are disatisfyed with the speed of the pump you can replace the pump latter.
Thanks, Rick
Clem Wixted
The Wood Spinner / Bill Hale
>Clem
It is not as much about how high a vacuum it will pull as it is to the seal you develope between the work piece and the pump. Also the porosity of the wood beeing held.
An open grain wood will allow air to pass through the wood and with a low volume pump you will not be able to increase the vacuum enough to hold the work tight. The mount must also be tight against the work.
Good turning and be safe
Bill in Casa Grande, AZ. (I use a Gast AC pump)
Walter Ahlgrim
>It has been my experience that you will need at least 1/3 horse power or 3cfm to over come the leaks in the woods we turn. Oil bath pumps are a poor choice in a wood shop as they spray a fine mist of oil in the air. This film of oil may interfere with your finishes. Don�t forget the hassle and cost of finding the correct oil, changing and disposing of it. The smaller the area exposed to vacuum the more inches of Hg the pump must pull to keep it on the chuck. The larger the area exposed to vacuum the more cfm the pump must pull to over come the leakiness of the wood.
Walt
Bill and Walter
Clem Wixted
>Thanks for the good input.
I passed on the unit because I will probably have some leaky wood as well as in other parts of my system, when I get it built.
I was given a older Gast oil lubed vacuum pump that needs to be rebuilt so I will probably pass on rebuilding it to keep oil out of my shop.
Clem
