Re: Serious Lathe tools
Rick Allen
>Please note that Serious Lathe tools are high carbon steel not HSS so blueing the tool while sharpening is a bad thing.
The tools are longer than other brands so you get a good long tool that has a good heavy feel in your hand.
The edge holding seams fine to me. You should always have a sharp tool for finish cuts so the edge holding is of little consquence to me.
I find the flute shape to be of my likeing and is simular the flute found on Crown bowl gouges which is slightly less "U" shaped than Sorby but no where near as "V" shaped as found on Glaser tools.
The flute is half the lenght of the tool and because the tool is so long the flute is longer than other brands. This is long lasting tool with the weight to dampen vibrations.
Is that what you had in mind?
