Alcohol drying per David Smith
Vicmarc.fan
>I am having a problem wraping paper on the outside of my bowls. Would it be acceptable to coat the rim and outside with Anchorseal? My understanding is the inside should dry quicker than the outside. Would't this do the trick?
Ron
Re: Alcohol drying per David Smith
Carole in VA
>Maybe, but I don't how Anchorseal might react to alcohol,if at all. I don't like to mess with anchorseal on rough turnings. Sometimes I have bark inclusions,voids,knots or cracks that have been uncovered in the turning process and I don't want to get that stuff into them. What I do with the paper is stick it in a paper bag, fold it up snug then cut or tear out a hole over the inside of the bowl, slap two rubber bands around it at 90 degrees to each other and toss it on the rack. I don't worry about it being as neat as a Christmas wrapping.
Kevin Gerstenecker
>I do pretty much the same thing as Carole does, and it seems to work well. What I have found that helps the paper conform to the bowl shape and hold on better is to wrap them right after they come out of the bath, and are somewhat wet. I pull them out, let the excess drip off for a minute or so, then wrap right away. This lets the paper get a bit wet from the Alcohol, and it folds and conforms to the shape, and stays that way as it dries. I also make sure I always handle wet bowls with rubber gloves on........Alcohol will absorb pretty quickly thru the skin, and it isn't too good for you.
(I always use brown grocery bags too, those work much better than newsprint....denser and allows slower drying, IMO.)
You can also just wrap the paper as best you can, then wrap a layer of masking tape around the outside rim as Dave shows in the tutorial, tightening the paper as you go.
ken chase
>Carole:
I rough turned a few peach bowls and did not soak in alcohol. I coated them completely with anchorseal and them placed in paper bag taped closed. I hadn't heard about leaving a hole in the bag. Is it all right that I didn't?
Thanks
Re: Can't get paper bags around here.
Al Crandall- NE of Indy
>All the stores around where I shop have only plastic bags so I was forced to find another alternative. I bought a 36" wide roll of brown painter's masking paper at Lowe's and it has performed great. Besides, a lot of the things I turn wouldn't fit into the standard grocery bag anyway. My procedure is to turn the bowl upside down on the paper and then fold the corners up and around the bottom of the bowl just like I was wrapping a present. A couple of short pieces of tape will hold the paper in place. Then I turn the wrapped bowl over and, using my pocket knife, cut a rough hole through the paper in the the center of the bowl. Quick, easy, and the paper stays tight to the bowl around the rim.
Pat Mulligan
>I do a lot of alcohol drying and I don't wrap anything.I get very few cracks and the ones I get are in areas very prone to cracking like knots etc.After the pieces drip dry I put them in a cool place to dry slowly for awhile before moving them to a drier place.Yesterday I noticed some norway maple roughed bowls foaming in the alcohol.Little rings of bubbles were coming up all around the rims.I wonder what is going on with that?
