Shavings disposal - PLEASE READ
Ed Moore
>Somehow the link I posted that listed the toxicity of different woods got eaten by Microsoft. I found a different source and copied the section on horses and black walnut. Here it is:
SIGNS: Horses are most often affected. When horses are bedded on wood shavings containing more than about 20% of black walnut shavings (which tend to be dark in color), clinical signs of laminitis (inflammation of the laminae in the hoof) can occur within 12 to 18 hours of contact, but 24 hours may elapse before signs manifest. Consumption of the shavings may cause signs of laminitis as well as mild colic. Affected horses become unwilling to move or have their feet picked up, are depressed, may exhibit limb edema and signs of laminitis. Difficulty in breathing (increased rate and depth) may be noted. Horses on pasture may show mild respiratory signs from pollen or fallen leaves.
Bottom line: Don't use black walnut for a horse's stall or bedding.
Re: Shavings disposal - PLEASE READ
More
JohnD
>Walnut shavings are not good for mulch either. The tree emits a toxin that limits undergrowth. If you notice you won't see undergrowth under a walnut tree. I am told by nursey to just burn it.
Re: More
Matt Berry
>Composting walnut shavings will take care of that problem. Once it has turned into compost it won't hurt anything.
Re: More
Terry Quiram, Roanoke Illinois
>I agree. I compost walnut all the time and my vegetables and flowers do not suffer.
Terry
Re: More
David Galloway
>That is completely new information to me. I thought you were to avoid walnut at all cost in the garden. I may give it a try. Thanks for the new info.
DAvid
Re: More
>Try throwing some nitrogen rich fertilizer in with the shavings and some lime. Grass clippings are great too. We can get another whole thread going on what kind of nitrogen to use, but that's for the gardening forum. I mixed up a batch of shavings and wet them thoroughly and they got so hot they were steaming. I couldn't believe it and stuck my hand in the pile. HOT! Exactly what you want to kill any weed seeds in the green stuff.
The Wood Spinner / Bill Hale
>Mix in leaves, grass clippings, kitchen green garbage and cow, horse and chicken manure etc. to make a good mix. Do not use dairy cow manure as they generally add salt to their feed. Chicken droppings are very high in nitrogen. Urea is the cheapest way to buy nitrogen. Turn the mix weekly or so and keep moist. Keep your pile away from buildings and combustibles as it can get very hot. If you cover the pile with a tarp the heat will kill all seeds and criters inside.
Remember the walnut shavings can be a great weed controll.
Bill in Casa Grande, AZ.
