We value your privacy.
>What is the correct procedure to maintain the tips on instant glue bottles. I bought cherry pickers which have only make the problem worse. Every time I go to use instant glue I can't get it through the tip and do not know how to avoid the problem.
>Ken, I clip the tip when I open it and toss the cap. Usually no problem with the tip clogging. On other way is to have a couple tips. Leave one in a small covered jar soaking in acetone. If the one you want to use is clogged just switch.
>Stuart just answered for me. I've tried everything and still get a clogged spout on occasion. Leaving the lid off at least a minute or two after using the stuff seems to work best. I also cut off part of the spout so the hole is bigger. I keep the jar of acetone handy and dump the clogged lids in there and then pull them out in a day or so so they are dry and ready for the next clog
>What you should NOT do is, when squeezing the bottle to blow the last drops out of the bottle tip, hold it up to your ear to hear if the air is passing through. Those last droplets in your ear and hair are very annoying!
>My favorite system if you are using the glue daily, is to buy the Micro Pipettes that LMII sells. I'm sure you could get them elsewhere, but the LMII size is critical. These little things allow you to suck glue up from the bottle, position glue more accurately than you can with the nozzle, and they clog less than the regular tips. I just leave them in the open air. The interior air volume is so low, it takes several days for the glue to go off. You can sometimes find a pin that will slide right in the MP, the only thing is that they also split them. I have tried ones from another source, but they were too large, these are barely 3" long.
>CA glue sets in the absence of oxygen, so if there's any in the tip and you put the cap on, well--you get the idea.
After use, I tap the bottle on the bench to knock the CA down from the nozzle. I never use the cap, so made a bracket to hold the bottle upright so it won't spill--a simple angle bracket of sheet metal, with a notch to fit the bottle's neck into. You could turn a little wooden cup with a wide base, dedicated to holding the CA glue bottle.
Those pipettes are just what I have been needing, I get annoyed with having to cut a big mouth in the nozzle and loosing control, the pipettes give you lots of control.
Do you keep the bottles refrigerated? I keep mine cold in a little box in the garage fridge door, never thought to clear the excess out of the tips, and always put the caps back on after use. I can't remember the last time I had a clog. Oh yes, I do remember - it was when I left a bottle out of the fridge for a few hours.
BTW, I read a tip once about how heat accelerates and cold slows down the setting. Some types of wood, like cocobolo, seem to act like accelerators for the glue so you have to be real quick with, for example, inserting a brass tube into a pen blank. However, if you put the blank into the freezer for 10 minutes or so you get a much longer working time.
Also, can someone explain why excluding oxygen makes cyanoacrylate glue set up faster? Why doesn't the entire bottle set up from the bottom, which seems oxygen deprived?
>If you are using the d@a%m spritzer bottles of excellent, don't store them int he same area. I was keeping them in the same drawer and apparently there is enough leakage from the spray bottle to trigger the CA. Lost several bottles before I realized. Also seems to be either weather or time related. Wonder if humid weather could make it worse? Seems too. I agree with keeping it cold and tapping the bottle on the counter to knock the glue out of the tip. Are those pipettes cheep enough to be disposable?
