Ebony Hollow Form
Mark Kauder, Phenix City, AL
>4" in diameter, Ebony, Bloodwood and Yellowheart.
Mark
Ebony Hollow Form
Mark
Re: Ebony Hollow Form
gary s clarke
>Mark, great looking hollow forms, what type of finish on most of them?
Jennifer@Indy.USA
>Mark, All of these are so fantastic! I love the smaller size of them...I'm kind of into a smallish phase right now. This one though is by far my favorite! It's just lovely. I love the soft edge to the opening...the form...the colors...it's so rich!
Bravo on all of them! I'm sure these will go quickly!
Jennifer
georgetroy
>Great looking work. Mark, you are really cranking the work out. I thought you had a full time job. GT
>I do, but I have an addiction to feed as well. You should know, you helped me start it years ago.
Thanks for all your comments, GT
Mark
>I use Nitro-Celulose Lacquer. Highest quality I can find. Right now that is Lawrence-McFadden Guitar Rubbing Lacquer.
Thanks
Mark
Ed Kelle
>This one is my favorite Mark. I usualy don't see many dark pieces and this one really works well. Those bowls are great also. Good job!
I like this one
TD
>They are all very nice Mark but this one is my favorite. Aren't you the same guy that I offered a lathe for 5 wood vessels about 3 years ago?
TD
Re: I like this one
>Yeah, But if I recall, it wasn't a VB-36 though.
Thanks, TD
Mark
George Van in WI
>Gosh Mark, you just posted some wonderful work and this is my favorite. Your finish on this black ebony against the Bloodwood is fantastic. I put this photo on my desktop so I can enjoy it for a while.
Thanks for posting, George
Re: Ebony Hollow Form-hollowing the inside with?
Jill
>Wondering: What do you use to hollow out these small forms? I have a hollow form I am working on but have reached a point that I don't know which tool to use to finish the bottom of the inside. I am very, very new at turning so I am not sure if I am using the right approach or tool. My form is 3 inches tall with a neck opening diameter of 3/4 inches. I have made it to apx. 1/2 inches down inside of the form so far without killing myself...........only a few catches and frayed nerves. :-)
>Because I do segmented turning, the inside is mostly hollow to begin with, so mostly I have to turn the inside to the thickness I want, and finish the surface of the inside. On this one, I use a small Sorby hollowing tool like "A" in the attached link.
One of the first thing you can do is use a drill to remove the wood from the middle of the bowl, down to the depth of the bottom, and then use one of these swan-necked tools to slowly open the inside from the top down.
Not sure if that is much help.
Mark
Here is the Link *LINK*
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=161-0850
Jill
>Holly Cow Mark I thought I was the only one up this late. LOL Thanks for your advice. I do have the hollow master (kinda like a.) and I am trying it but it seems to be too wide to get into the neck very well.I seem to catch it also, not sure at what angle to have it. I do need to get a chuck for my tail stock so I can drill my forms out first. I think I will have to drill it out and then make another attempt at using the hollow master. I can't wait to finish this one.
Re: Ebony Hollow Form-hollowing the inside with? *LINK*
Phil Joines
>I prefer taper shank drills to using a chuck. They are too long to use on a mini with a standard bed. If you get one use vice grip pliers to keep it from spinning in the tailstock. 15/32" is the largest made for a #2MT.
15/32" drill
>Actually, I was up that late because I am on call for our IT department, and I was awakened by my pager because one of our servers was down and had to be restarted. While waiting for it to come back on line, I checked the boards.
I have a Sorby Hollowmaster and it is one of my favorite hollow form Finishing tools with the teardrop shaped cutter. It works adequately for hollowing mid-sized bowls if you use the straight 1/4" cutter, but I would never use it on any thing with an opening less then about 1.5". You really need one of the smaller swan necked hollowing tools.
Mark
Re: Ebony Hollow Form-ah oh I see
Jill
>Another tool purchase comin' on!! Yes, I think I have picked either too small of a hollow form or too big of a tool. ;-). Guess being a newbie comes with A LOT of lessons. Out to do some shopping.
