Inside-Out Petal Vase
Ken Grunke from SW WI
>A vase done by the inside-out method, of White Oak. 9" high, 2 1/2" across the petals.
Sanded to 1500 grit, only one coat of wipe-on poly so far to keep the gloss down for the photo.
Re: Inside-Out Petal Vase
Don Tewell
>I'm fairly new to turning and have heard a lot lately about 'inside out' turning. What is this and how is it done?
Jennifer@Indy.USA
>That is really pretty Ken. I'm not familiar with the inside out method? Can you explain.
Thanks!
Jennifer
Inside-out turning explained *LINK*
>Jennifer, and Don:
An inside-out turning is laminated from 4 square pieces, whose inside profiles are first turned with the insides facing out while temporarily glued together. Then the pieces are pried apart, and glued back together permanently with the turned profile facing inwards, and the outside is turned. Check out the link at the bottom for a tutorial I put together back in 2002, when I demoed inside-out ornaments for my AAW chapter--that goes into fairly good detail on the technique.
And here's a 3D graphic of the first stage, with the inside profile turned, ready to pry apart, and reglue:
Inside-out ornaments
Re: Inside-out turning explained
Don Tewell
>Thanks. It looks like I may even be able to do that, even with my limited turning experience. BTW, beautiful piece you turned.
>Thank you, Don.
One tip I should mention, and ought to update the pdf tutorial with, regarding the first stage temporary glueing.
I now use double-stick tape, the stuff used for plastic storm window sheeting (1/2" wide). If you have a 4-jaw scroll chuck (Vicmarc, Nova chuck, etc) you only need tape 1/3 to 1/4 of the length at the tailstock end, and the chuck holds the other end securely--assuming it's not too big, of course.
Apply momentary pressure with a c-clamp to each joint, and you won't be able to easily seperate it without a chisel. You can use a little tailstock pressure to hold that end, but be careful--you don't need much.
Roger H
>A very attractive piece and a very helpful description of the process. I hope to experiment more with this technique--my first attempt certainly was a learning experience! (stove wood)
Thanks for sharing. Roger
