We value your privacy.
>We use a machine to do things it was not designed to do. Example:
Bandsaws were not designed to cut end-grain. Bandsaw blades are not designed to cut end-grain. I learned this from my Woodmizer experience. If you try to cut a goblet blank or box blank from a quarter log by sitting the blank upright on your bandsaw you are going to have to buy a new calculator because when you count on your fingers things aren't going to add up. Reason: bandsaw blades load up when trying to cut end-grain. A loaded up blade is the same as a dull blade. When the blade gets loaded you push harder to make it cut. Then when you turn the blank and start cutting across the growth rings the blade unloads and starts cutting very well again; too well! The blanks moves forward much faster than you anticipate and your hand is there pushing the blank and.....need I say more? Be especially careful when sawing in parallel with the growth rings.
>I routinely cut up to 12" thick on the 14" Delta with riser block.
Very little force should be needed. If I find myself having to apply force to cut through a tall blank, I stop and change blades, resharpen, and/or clean the blade. (And be SURE the saw is sufficiently tensioned. Otherwise the blade may bow in the cut and cause increased resistance, a horrible cut, and require a dangerous amount of force. I know this from my own and others' experiences.)
If the bandsaw blade loads up when cutting parallel to the grain you might need a blade with fewer teeth. Brian Hahn once wrote an excellent note about sharpening bandsaw blades. He wrote: "For re-sawing I use a 5/8� - 3 tpi hook tooth blade (Olson from Woodcraft). I�ve tried other blades, but this is the one that works best for me."
He removes every other tooth with a grinding wheel. This is similar to one method of changing a chainsaw chain from crosscut to ripping use. He goes on to say this modification "makes it a 1.5 tpi blade with a L-C-R pattern. The blade cuts at least twice as fast because there is more room to clear the sawdust. It also seems to cut twice as long before it needs sharpening. This also works for a five-tooth pattern , but if you have a two-tooth pattern (no raker/center) you�d want to remove two out of three teeth to maintain the pattern."
>12" thick is no problem when sawing across the grain; this is what the saw was designed to do (with the proper blade). However, if you stand the piece of wood up and saw it with the growth rings running parallel to the blade then you are doing something that a bandsaw cannot safely do. There will be only a small portion of the cut where you will line up with the growth rings and this is where it becomes dangerous. As long as you are crossing growth rings everything will be ok. However, when you make a turn and the growth rings are in line with the blade the blade will load up because the "chips" won't break and eject; you'll get long, stringy fibres that will quickly fill your saw housing and clog the blade. The saw will feel dull for a moment and you will instinctively push harder. As soon as you make a turn the blade will throw the "strings" out and start back cutting again. Many times you hear of people that were cut saying they were pushing a dull blade but this is more likely the cause.
Since my band saw is not capable of such a deep cut, I usually slit it with a froe. Am I doing damage to the blank by exposing it to the shock of having wood split away?
>Since you are splitting, the grain will be straight within the piece (which is good) and you are not likely to lose a finger doing it that way either.
I understand what you are saying, but I found the proper blade makes all the difference. I was indeed referring to standing the block up and cutting tangentially, round, or slicing off corners. I usually use a 5/8" blade so cutting a small diameter round is not practical so I might cut the blank 8 or 12 sided. Many of these tangential cuts go through sections where they cross the grain then follow the grain for a while. With the correct blade there is very little clogging, no need to apply pressure, and no sudden dangerous surges. (At least not with the wood I've been cutting: oak, holly, cherry, hard and soft maple, walnut, box elder, sycamore.)
But it is always a bad idea to have your hand in line with the cutting edge of the saw, regardless of how much wood is between you and the blade at the moment. If you run in to a punky area, internal rot, or something breaks you could in fact change your ability to pick your nose or play the piano. I like to grip behind the blade if posible, and if not, use one hand behind the blade and push with a stick. Here's what I think is the safest way: I often stand to the side of the bandsaw and move the wood from left to right for both straight and curved cuts. This keeps both hands away from the path of the blade.
However, I'm certainly not suggesting anyone into make a cut they are not comfortable with. If it feels dangerous, do it another way.
While discussing bandsaws safety, it is also a good idea to remember to never cut an unsupported part of the work, for example crosscutting a large section of round limb. The blade can easily catch and pull the unsupported part towards the table, at minimum jamming the saw and ruining at least the blade, and possibily taking a finger or thumb with it. I usually support such rounds with curved offcuts from earlier cuts.
Now here is something dangerous I catch myself doing far too often at the bandsaw: cutting with clutter. I just want to make one or two quick cuts and the floor is 4" thick with shavings mixed with a few offcuts. OSHA would have a fit. I certainly need to practice better housekeeping discipline around my lathe.
>Actually, anytime you're 'forcing' anything, power tool or otherwise, you're asking for trouble. My left hand is very tired of my right hand hurting it that way.
>The Timberwolf 3/8" x 2 AS blade does a great job on end grain cuts on green wood. The AS stands for the alternate set of the teeth which opens up the kerf. It is rated for 6"-12" thick green wood. They also make a 1/2" version of this blade. See the link below.
>David, I also prefer the Timberwolf blades. They are the best blades I have found for turner's needs. It is still necessary to use caution when cutting end-grain with these blades but they are the best that are available. Being aware of a potential problem is the best way to work safely.
