How to make the burl pop????
Lan Brady
>I am making Christmas ornaments from Maple burl. How do I make the grain pop out?
I sanded through 400 grit and tried Krylon spray, Friction polish,and CA glue(seperately). All still appeared flat. No depth!
I need help!! In more ways than one!!!
Thanks, Lan
Re: How to make the burl pop????
Ryan McMullen
>Use BLO - Boiled Linseed Oil - that always makes the grain pop on my pens.
Ryan
I could tell you but then.....
TD
>you know the rest.
TD
If milk doesn't make it POP then try BLO and dye.
Dave Smith, Longview, WA
>Hi Lan,
Any thing that penetrates the wood will be absorbed more in the end grain of the figure and differentiate it from the rest of the wood. Dye and BLO will do that. A smooth finish such as rubbed lacquer will help bring out the figure.
Good luck and post some pictures.
Dave Smith
Popping Excedrin right now in Longview, WA.
Re: Spindle turning chatter - - wisdom sought !
Ken Grunke from SW WI
>Try sanding up to 1200 or 1500 grit, use 2 or 3 coats of wipe-on poly, then buff.
I use Norton Black Ice sandpaper available at auto parts stores. 1500 grit makes the wood shine before any finish is applied, and the poly becomes part of the wood instead of a surface film.
subject line was cached from an earlier post
Re: If milk doesn't make it POP then try BLO and d
Lan Brady
>Ryan, TD, Dave and Ken,
Thanks for the help. When I get home tonight, I plan to try each of these. I'll let you know my results.
Lan
Phil Joines
>Try light brown sprit based leather dye thined about 4 to 1. Then sand most of it off.
