Record (DML) lathe
Record (DML) lathe
Record (DML) lathe
Jill
>Hi To All. Any owners of a DML lathe? I was wondering if anyone out there owns one or can give me any pros/cons to look into? I am considering purchasing a used one.
Thanks,
Jill
Re: Record (DML) lathe
Edward
>Hello Jill: I have one of these lathes and I use it a lot for between centres work. The Record lathes are smooth, quiet and accurate. They do have some drawbacks; only 3 speeds. I set the belt to the speed that I want and leave it there. The newer lathes have a 4 step pulley to give 4 speeds, but you would have to order the upgrade kit parts from England. Most people upgrade the set screws used to tighten the tool rest to ratchet handles. The threads are metric and it might be hard to find the appropriate handle. I go to Home Depot for metric fasteners.
I changed the two black pipes that make the bed for solid steel 1 3/8 machine shaft.
It is nice that the lathe can be taken appart to move it as the weight of the cast iron parts does add up.
Replacement bearings should be avalible at any bearing supply store, and they are easy to replace. I get replacement belts from England. They are "poly V" type and might be available fron Gates belts.
I would call the DML a heavy lightweight lathe, even though it weighs about 150 pounds, I think.
The DML uses #1 morse taper drive and live centres. these are available from all the mail order companies.
How much is the asking price? ANd what will you be making on it?
>Jill
I have a Record Coronet, check your email.
Jorge
Poly-V Belts .
Fred in NC
>I buy them from www.aarubcorubber.com. They have all sizes, and are very reasonable, including low shipping charges. No affiliation.
Re: Poly-V Belts .
Jill
>Fred,
Thanks for the information.
Jill
>Jorge,
I checked my email. Thanks! Check my response.
Colin Spencer
>Jill, I have one of these and it is what I started turning on (now have a DVR as well). It is a good starter lathe and is of much better quality than the Chinese ones that come from most of the low end suppliers. The spindle thread is 3/4 x 16 so chucks and accessories are readily available both in the US and the UK. The bigest limitation is the maximum diameter of bowls that you can turn unless it has the swivelling head and outboard turning rest. I turned some large out of balance pieces on mine as it was mounted to a heavy stand without issue. All in all if the price is right I would go for it but be aware of its limitations and if you get hooked you will want something bigger.
Colin
