WoodMizer for turning blanks?
JKJ in East TN
>For those of you who use a bandsaw mill to produce or help produce turning blanks, can you provide some experience about holding and cutting small pieces?
I currently prepare blanks with a chainsaw and Delta bandsaw. I've got a new Woodmizer set up now and it would certainly cut thick blocks a LOT faster if I could figure out a way to hold irregular pieces, short cants, and blocks securely.
I thought of making a glued up hard maple "workbench" surface to lay between the rails. Put a short fence down one side. Maybe a short fence across one end. In this block, I would cut a number of holes for square or round "bench dogs", welded from steel stock. Then weld some type of clamp on the top of other stock. It seems to me a number of clamps and dogs could securely hold just about any shaped chunk of wood.
I know the blades are made for ripping. How well does a bandsaw mill work across the grain on a large block?
Any other ideas, advice, experience, encouragement, warnings?
Re: WoodMizer for turning blanks?
Sure!
Barbara Gill, Remlik VA
>I have cut several blocks to rest on the space between the two center rails. I put a board against the two center back supports to help hold the piece. Then I dog the log. I will usually cut a small flat spot on top of the first piece and then drop down and make the "center" cut.
Then cut out the pith section. I often will make it thick enough to use the good part for stopper blanks, hollowforms, etc.
Then turn the piece over, put the block that fits best under the unsupported end and make the second cut. Tah Dah...
If I haven't been clear enough, let me know.
I just sold my Woodmizer but.....
TD
>I sawed a lot of small pieces of wood on it.
Forget turning the short log 90 degrees; it'll only clog up your blade guard.
Saw all logs lengthwise; If they are short you can use scrap lumber to make a sacrificial fence to hold the piece in place for sawing.
Sectioning is best done with the chainsaw.
that is the way we do it too
Tom Sontag - St. Louis
>If you only have firewood lengths, forget the rest of this, but TD's method has been extremely efficient for us. Just rip 4" thick +/- slabs and just chainsaw blanks from them. Some slabs I wait for them to dry a bit, some can't wait.
JKJ in East TN
>Excellent, thanks! I was making things too complicated.
I do have some short pieces and crotches that will not fit on the crossrails. I was hoping to get nice flat ends on blocks but I guess I can still do that on the delta.
James McClure
>Which WoodMizer did you get?
JKJ in East TN
I bought the LT-15, manual mill, 15hp, one bed extension for 17'+ logs. So far I've cut some red maple, persimmon, and yellow poplar. The thing is good fun! No hydraulics on this model, but I have a tractor with a FEL for loading logs.
It was pretty easy to set up if I ignored the video tape that came with it. (The tape was obviously made for an earlier model) I found some minor problems with the manual as well. I hope to discuss these with Woodmizer and write up a little doc on my experiences when I get time.
>I had a guy saw a piece of walnut stump that had gorgeous curly grain on a band mill. It was about 30" long 12 wide and maybe ten thick. It was very old and dry and there was nothing "regular" about it. He just looked around and picked up a scrap piece of 2 x 12 his mill would grip and nailed my block to it. Drove two 16d nails in from the under side into part of the piece that was cracked and split. Tapped in a couple of wooden wedges to level and chock it. Then he sawed it from the top down, keeping in mind how tall the nails were. Left me with a "plank" that was about 1 1/2" thick that I have cut a bunch of little pieces out of.
James McClure
>Terrific! Looking forward to hearing more about it.
I looked into getting one a while back, but decided it was too much to take on.
JKJ in East TN
That's a good idea. I wondered about using big screws, something like mounting an irregular piece to a faceplate for turning.
Curtis Seebeck
>I don't have a WM but I do have a TimberKing 1220. I use it to cut a lot of stuff but lately mainly bowl blanks. I actually prefer to have the logs for bowl blanks in shorter pieces since I don't have to worry about wandering pith. I have a 2x8 that is long enough for my dogs to catch on each end. I screw the 2x8 to the log and then dog it up and cut away. Works great and is quick and easy.
Curtis Seebeck
www.AdoptWood.com
Selling quality pen and bowl blanks to finiance our adoption
JKJ in East TN
Curtis,
Do you use large diameter lag screws, deck screws, or what? What depth into the wood do you find necessary? How many screws, and just down the center of the log or on either side for more stability? Or perhaps I'm worrying about nothing and the extra stability is not needed.
