Re: hollowform question
Raymond Overman in SC
>John Jordan did a demo for our club and said that you should finish turn a hollow form as uniformly thin as possible and then restrict the airflow around the piece. It will warp but being a hollow form, it doesn't matter. A lot of the warping, cracking, and uneveness of a piece comes from selecting the right place in the wood. The mouth of the hollow form should be in line with the pith and equal amounts of wood should be on each side to accomodate a uniform warp.
Personally, I still finish mine to 1/10 thickness of the diameter, place it in alchohol overnight, then restrict the airflow around the piece for approximately 3 weeks. I don't know if the second part of the equation is all that's required or not because mumbo jumbo or not, I get the result I'm looking for and have had good result with peach.
Good luck.
