Kelton Hollowing System question
Ted Owen, Pittsburgh
>I bought a Kelton Hollowing Rig to go with my new lathe. Have been setting it up the past couple days, and I have a question you folks may be able to answer.
During setup, you adjust a 3-bar slide arm tool holder at both ends of its travel, making sure the adjusting arm is tight enough to prevent twisting of the slide arm but not so tight that it restricts movement.
I have adjusted the holder at both ends, but there remains play in the middle--about 1/16", or perhaps 5 degrees of rotation. I'm guessing that the cause is one or more slightly bent arms. When I get a chance, will take things apart to determine whether the arms are true.
Has anyone encountered this problem before? Was it caused by a bent arm? Or do you just live with it?
BTW, this type of problem is consistent with the poor fit and finish of the system otherwise. Grinding was required on two components to assemble them.
Photo is from Lee Valley from whom I bought the system. Thanks in advance for any thoughts.
Best, Ted
Re: Kelton Hollowing System question
Re: Kelton Hollowing System question *LINK*
joaz
>Be sure an put a small level on the cross bar to make sure it is level. I did not have any problems setting up my rig. If I were you I would send It back, if the bar is bent, you shouldn't do anything to void the warranty.
Just my 2cents.
http://www.maine-web.com/woodturning
georgetroy
>I have the Kelton Hollowing System. I didn't check anything. Just hooked it up and went. Mine is about 3 years old now. That device sure is heavy and awkward.
Dave Winters, Steamboat Springs, CO
>I had the same problem. Never did figure it out. I took the bars off and they seemed true, but no amount of fiddling cures it. In short, I'm living with it. Let me know if you figure something out, O.K.?
I agree George, heavy and awkward and
TD
>very limited in what it can do. I use the cutters in my Sorby arm brace but the rest of it is now retired. It did some shapes quite well but others it did not do at all. I now use the Jamieson rig and the Sorby arm brace and am able to do a lot more shapes.
Steven Roxberg
>I had the same problem and was able to easily solve it and make the unit better.
I purchased some Slick Strips tape from Woodcraft for $6.50.
From the Woodcraft website :
Slick Strips reduce friction to the point where almost everything moves like it's mounted on ball bearings! This special UHMW (Ultra High Molecular Weight) adhesive-backed flexible plastic film has a low coefficient of friction and a high abrasion resistance that surpasses even Teflon.
The strips accomplished two task, one the bars slide very smooth, and the additional thickness allows you to tighten up the slack.
Another tip for the system. The horizontal bar is difficult to set and I like to remove it when it's stored. I made two blocks of plywood that hold the bar at the correct height while I tighten the bar down. I like my cutter to be just slightly above center and calculated the height of the plywood with that in mind.
I can remove and replace the system back to the exact same spot in minutes.
If anyone would like photo's or additional descriptions of how this works please let me know.
This will solve your problem.
Greg Jensen
>You already got the answer. Use two pieces of slippery tape or drawer slide tape on the top and bottom of the cross bar. These will smooth everything out. You should have slack in the set up to allow easy movement. I spray mine with WD-40. When you touch the tip to the hollow forum the three bar slide arm will rotate counter clockwise once it has rotated slightly the system is loaded up. The rig is just an anti-rotation device. It does not need to be tight.
Greg
>Thanks, everyone, for your thoughts and advice. I've just ordered some of the slick tape.
It also sounds that the looseness is not an issue in any event, once the cutter contacts the work.
Best, Ted
Re: Use candle wax for a lubricant.
Al Crandall- NE of Indy
>Ted, I use a home made hollowing system based on a different design, but I think the use of candle wax for a lubricant wherever two metal surfaces slide against each other will make a huge difference in the amount of friction you experience. This means the bottom of the boring bar and its extension, the top of the lathe tool rest and the two torque resisting bars, and both top and bottom of the secondary rest bar. When everything is waxed on my system, the boring bar glides in any direction like a puck on an air hockey table.
