bowl gouges
bowl gouges
bowl gouges
Pat
>I having a real hard time roughing out a bowl with my 3/8" bowl gouge, what size gouge would you reccomend, 1/2" or larger?
Re: bowl gouges
Re: bowl gouges
georgetroy
>You may not want to hear this but. You should have a 1/4", 3/8", 1/2" and 5/8" bowl gouges all the best quality you can afford. No
China stuff. A 1/2" or 5/8" bowl gouge is good for roughing out bowls, much of that depends on size of your projects. A fingernail grind will be good of most uses. GT
Re: bowl gouges
Re: bowl gouges
Pete in Holland, MI
>I do most all of my bowl turning on my 12" swing JET with a 3/8 Sorby bowl gouge. Bowls are often as large as the lathe will let me swing, The right fingernail grind geometry is key. Sharpness is critical. You'll need to buy a sharpening system. Buy Bill Grumbines(sp?) DVD also. I refer to it often.
Pete
Re: bowl gouges
Re: bowl gouges
Jennifer@Indy.USA
>Pat your 3/8 gouge should be just fine. I usually use my 3/8 for 90% of my bowl making. I may go to the 1/2" for initial roughing the outside because there's more heft to it, and then perhaps a 1/4 gouge to get into tight spots when finishing the foot. Just make sure that your tool is sharp and you're presenting it to the wood properly. I love the 3/8 size so much that I have 3 of them with different grinds on them for different situations. It's definitely my favorite all around bowl gouge size.
Jennifer
Re: bowl gouges
Re: bowl gouges
Bill Howatt
>Pat,
If you are having a real tough time I would say your problem is more likely related to tool presentation, sharpness, perhaps grind shape rather than the size of the gouge.
Depending on how far the tool rest is away from the cutting surface 3/8 may be a bit on the small side. I have a 3/8, 1/2 and 5/8" gouges. When I started I liked the small gouge since it didn't seem like such a "hazard". I now use the 5/8" gouge for almost everything unless there is a clearance problem. It seems more secure. Most of my bowls are under 13" diameter.
The sizes mentioned above are the diameter of the gouge shaft. English gouges, such as those made by Sorby, use the maximum width of the flute as the gouge size. My 5/8"dia Sorby is labelled as 13mm or 1/2" by Sorby.
Bill
Re: bowl gouges
Re: bowl gouges
Wally Dickerman in Arizona
>When teaching turning classes, if a student shows up with a new 3/8 in. gouge, I offer a 1/2 in. (English messurement) gouge to try. Nearly always the student will prefer the larger gouge.
Wally
Re: bowl gouges
Re: bowl gouges
Rick Allen
>If you are having problems with a 3/8" bowl gouge then you likely will have problems with a 1/2" bowl gouge.
Your best chance is to get some hands on instruction. You will be amazed at how simple turning a bowl is. You will also come to understand how imposible it is to turn a bowl without having had hands on instruction.
Good Luck
Re: bowl gouges
Re: bowl gouges
George Fitzpatrick - Springfield MA
>I have to agree. I have been using a 3/8 inch bowl gouge and during a recent bowl class used a 1/2 inch gouge. Liked it so much better I went to Woodcraft last night and got a Sorby 1/2 inch. Just seems the larger gouge is easier to work with.
George Fitzpatrick
maker of fine sawdust
Re: bowl gouges
re: bowl gouges
Terry Quiram, Roanoke Illinois
>My go to gouge is 5/8. For delicate last pass cuts I use 1/4. I have 2 3/8 ground at different angles but rarely use them.
Terry
Re: bowl gouges
Dick Hines
Re: bowl gouges
Dick Hines
>I have 2 bowl gouges. Both at 1/2". One is a Crown Pro-am with the Ellsworth grind and the other is by Sorby that I have the Ellsworth grind.
I use them for most of my turning. Havinf 2 makes for quick roughing and finishing. I sharpen them both and turn away. When one stops cutting clean I just pick up the other and keep going.
Re: bowl gouges
Re: bowl gouges
MP Wall
>I started on a 1236 jet and used a pro pm 3/8 with a swept back grind to learn on, when I bought a 1/2 P&N bowl gouge and put a swept back grind on it it was so much easier to use. Now the 1/2 is my mainstay and the 3/8 is the final pass or tight situation gouge. Of course with the 1/2 I could stall the 1236 so I had to get a bigger lathe to really fling shavings with it.
MP Wall
Re: bowl gouges
Re: bowl gouges
>I have a 5/8 "shaft" gouge and the Ellsworth grind. It does 90% of what I do. Get the sharping system. I have not tried others because I am so happy with this one. Instruction is a great thing and so are videos.
