nuking wood
Pat
>I just finished reading a article in a book about drying your green wood in the microwave, how does it work, any good?
nuking wood
Pat
Re: nuking wood
Garrett in Victoria
>I've tried it with mixed results. The major key is patience of which I am in short supply. As with all fast-dry methods, it works remarkably well on some bowls and woods, and doesn't on others.
After you've roughed out the bowl, put it in the microwave on low power for a couple of minutes or until warm to the touch - not HOT - let cool, repeat, repeat, and... until dry. Russ Fairfield's useful tip is to touch it to your cheek and if it feels cool it's still wet. When dry finish turning it. You can do the same thing in a warm oven.
Cheers, Garrett
Re: nuking wood
Scott Hurley in N. VA
>I tried to speed up the drying process on this bowl blank a couple of months ago. The trouble is, it was already more dry than I had thought. 2 minutes in the microwave on high, and smoke was coming out of the microwave (not my wife's good one...) The whole shop smelled like smoke for days. Luckily, it didn't burst into flame or damage the microwave. It had already been sitting on the firewood pile for a while before I took the picture - that's why it's covered with mildew.
Re: nuking wood
Bill Crommett
>The secret to any drying process is to slowly and evenly decrease the humidity throughout the wood. I have done this with small pieces in the microwave by taping up most of the inside vent holes so that the moisture does not escape too fast. Commercial kilns decrease the moisture by the numbers, and if they try to hurry up the process they end up with case-hardened lumber that is dryer on the outside and subject to splits and checks.
Re: nuking wood
JKJ in East TN
>Pat,
I've used that method to dry several pieces. I weighed the wood carefully (and wrote the weight on the wood), heated for 30 seconds, then let cool completely. It took 1/2 hour or so to cool each time. When cool, or when I remembered, I repeated the cycle until the weight quit changing significantly. This took many cycles over the period of a couple of days.
The result was much faster than letting air dry (or any other method I know), but it does require a bit of patience and attentiveness.
It's the heat that vaporizes the water and lets it escape quickly. If you set the piece on a flat surface or paper towel while cooling, it will get quite damp underneath. Best to use a rack for cooling.
Also, you DO have to restrain yourself from overheating or the wood will burn, perhaps inside where you can't see it right away. (This is what I've read, not experienced.)
Re: nuking wood
Earl Eyre
>I have found it works quite well on most wood, but as has been said, sometimes you will still get checks. I do it much faster than some, but still slow. Usually about 2 min on 30%-40% power. Let cool about 20 min in the microwave, don't open the door (slows down humidity evaporation), do it again. It usually takes 5-10 cycles and it's done. I can get it done most the time in 2-3 hours, if it is a bowl or vase rough turned to about 3/4-1 inch.
Earl
Don't use "high", use the defrost cycle
Ric Taylor
Re: nuking wood
Greg in Oshkosh
>NOTE that the microwave tubes only have one power, that is HIGH. So 100% means the tube is on 100% of the time while at 40% it's on 40% of the time. Microwaving on defrost just means you are having the microwave turn itself off 80% of the time rather than doing it yourself. The key is not to get the item too hot. You can use high or defrost but stop before you are boiling water out.
To help prevent cracking, it would be better to let the water escape from the inside of the bowl rather than the outside. As the inside shrinks the wood compresses tighter. on the outside it shrinks to a smaller diameter and will pull away from itself cracking. That is why Dave Smith wraps the outside of the bowl after alcohol soaking. Let it dry from the inside.
Re: nuking wood
Ric Taylor
>I've been doing this for several years using several different microwaves. Using the defrost cycle gives the best results by far.
Put the wood in a paper bag, and defrost it for 5 minutes, then let it cool for at least an hour. Do this over and over again for as many cycles as it takes. I have never lost a piece due to cracking or had any wood-smoking problems on the defrost cycle, but I have lost pieces using other cycles.
Ric
