Incra Miter 5000 Owners??? HELP!!
Rob Ceraso
>I'm looking for some guidance here. After over a year of contemplating, I finally took the plunge and ordered the Incra Miter 5000 sled system. Much to my disappointment, when it arrived both of the MDF sled panels were badly warped. A call to Incra and another pair were on their way. They arrived last night and guess what... Yup, just as badly warped as the first pair.
I can't believe that I'm the first person to have this problem and I was wondering if any of you have the Miter 5000 and if you've experienced anything similar?
I'm a little more than concerned that even if I do eventually get a pair of panels from them that are flat, how long will it be before they too warp in my shop. The whole concept behind the Incra miter gauges is dead-on repeatable accuracy. How accurate can it be if the sled rocks on the saw table?
Do I return it and look for an alternative or do I keep the faith and keep trying? Any experience or just general guidance is greatly appreciated.
Thanks,
Rob
Re: Incra Miter 5000 Owners??? HELP!!
Denis Lalonde
>I have the Incra 3000 and tried to buy the the board to upgrade to the 5000, these are no longer available, wonder if this is the reason??? Denis
Allan Campbell
>Rob,
I suggest you keep trying. It really is a good tool.
When I bought the 5000 at a woodworking show about 6 years ago, the salesman demonstrating it said you never had to do test cuts, it was always exactly accurate and repeatable. I thought, "It looks good, but he has to be puffing. Nothing is so good that you don't have to do test cuts."
I took it home and set it up carefully, which took a bit of time, and he was right. I make a lot of picture frames which are really fussy, both as to equal length parts and exact angles, if you want perfect miter joints. I also use it for 90 drgree cuts and the occasional odd angle, so the angle is reset frequently, and it is dead on every time.
It also acts as a tablesaw sled and accurate cutoff fence, eliminating tearout.
Good luck on getting the repair parts.
Allan
Rob Ceraso
>Allan -
Thanks for the advice. Are your sled panels dead flat (or at least very close to flat) - or is there some tolerance for warpage here?
Both of the sets I have gotten have about a sixteenth of an inch cup to them which translates to the potential for any corner of the sled to raise an eight inch off the saw table. To me this is unacceptable.
Thanks,
Rob
Bob Way, Canton, MI
>Rob,
I don't have the Incra 5000, but I made a similar setup using a 2000 miter gauge and 1/2" baltic birch plywood. The plywood has remained quite stable. I know the 5000 comes with the panels, and it'd be nice to get what you pay for, but it really is a nice setup and might be worth making the substitution
Allan Campbell
>Rob,
I don't detect any warp in my boards. I agree that a warp would throw the geometry off and suggest you work with Woodpeckers to get yours replaced. The service at Woodpeckers is as good as any I have seen.
Allan
