Glue Blocks
Glue Blocks
Glue Blocks
Doug Reynolds in Seattle
>I glued a block of poplar lumber (dry wood) to some wet wood with a new bottle of thick CA glue on one piece and accelerator on the other. Let it set overnite. Block pops off under moderate (non-turning) pressure. What is going on and how do I fix it?
Re: Glue Blocks
Re: Glue Blocks
>Doug 2 things come to mind. First is you may not have used enough CA glue. I make sure thier is plenty. The second this is old glue. Is your glue old. If it is that is the problem. I taught a workshop one time and we had piece flying all over the place. I suspected the glue so I opened a new bottle and we didn't have another piece come off the rest of the workshop.
Oops I just thought of one more. I put the glue on one part and the Accelerator on the other. This way they don't dry until you put them together. If you spray the glue and then assemble the parts you would get a very weak joint if it glued at all.
These are my guesses. None of which may be correct but problems I've seen in the past.
Re: Glue Blocks
Re: Glue Blocks
Wally Dickerman in Arizona
>Glue block failures are usually caused by not using enough glue. Use med. CA. There should be squeeze-out after firm hand pressure. I put glue on both surfaces and after 30 seconds give just a light spritz of accelerator. (don't use clamps) You're making a glue joint, so make sure that both surfaces are true and flat. You shouldn't have to wait after the glue up. I mount mine on the lathe immediately.
I use alder for glue blocks because alder just about never warps, so you always have a good flat surface. Living in Seattle you should have good access to alder lumber.
Wally
Re: Glue Blocks
Re: Glue Blocks
Earl Eyre
>I was recently watching one of Bonnie Kleins tapes (1990) and she put a bunch of glue on one piece, pushes the two pieces together and wiggles them around, pulls them apart and sprays accelerator on one and then pushes them back together. They grap immediately and she puts them right on to the lathe. I tried this on an Intarsia piece I've been working on and it really does work like a charm.
Earl
Re: Glue Blocks
Re: Glue Blocks
georgetroy
>Your blocks should be used sooner than later. Wet wood shrinks. Best results will be too use afterwards in a few minutes
