Slightly OT - 2-by beam capacity
Tony Shaftel
>I need to mount an overhead track for my Harbor Freight hoist on 2x4 or 2x6 crosspieces between roof beams. The 2-by length will be 56". The track will attach to the centers of two crosspieces. Does anyone know where I can find the load capacity at the center of such a crosspiece? I can double them up if necessary but it would be nice to know in advance what is really required.
Re: Slightly OT - 2-by beam capacity
Re: Slightly OT - 2-by beam capacity *LINK*
>I hope this link works, I'm a subscriber so it works for me. You figure at least 280 psi. I'd double it.
Wood properties
The Wood Spinner / Bill Hale
>An old farmer trick is to laminate a piece of metal flashing between 2 x material and get extreme added strength.
Bill
Don't know how...
Tony Shaftel
>...to translate 280psi to what the max downward force can be at the center of the beam. The track (with the hoist and a load hanging from it) will be attached in the center of the beam. Does that mean 280 lbs (hoist plus load) is what the beam will hold safely?
JimQ
>Whoa! Back up a minute. Have you checked to see if the roof beams are even capable of supporting the hoist, much less the load? Most roof structure is designed for the local snow and wind loading with not much extra. Here in Phoenix they don't allow for any snow loading and the roof trusses are light weight compared to what you would see in the northern Rockies. You may need to build a framework to support the hoist from the floor rather than hanging it.
JimQ
Re: Don't know how...
>Will your cross supports hold up a load of 440 lbs and the weight of the hoist? The answer is probably, especially if you have twinned 2 x 4s or twinned 2 x 6s (better yet) fastened together (the plate between them is a great idea). The breaking strain of the two twinned cross supports (on edge, with the 4" or 6" perpendicular to the ground) should be well over 500 lbs. The deflection with the twinned beams (particularly if you use 2 x 6s) should be minimal.
Reservations - you say you are going to fasten these between two beams and the span will be on the order of 56"? How are you fastening the cross-supports to the beams? Simpson strong ties? Screws? Nails? Bolts? You then want to mount your track to the cross-supports. How does this fasten to the cross-supports? Screws? Bolts? I am worried about the strength of your fastening devices with a shifting load on a track. I have images of screws working out and tracks coming down.
Should work
Tony Shaftel
>Good question about the roof beams. The beams are 4x10 or 4x12 and the previous owner hung an engine chain hoist from the one in the middle of the garage--my supports will be between the wall plate and the first beam out, so it should be much less strain than he put on the system. I doubt I'll ever lift more than a 100 lb blank, so the roof won't even notice.
2x6's sound like the way to go. I plan to hang the track from a 3/8" through bolt running through a hole drilled down through the middle of the twinned 2x6's--no lag screws to come loose, though I doubt they would if they were long enough. Simpson strong ties at either end of the spans.
Thanks for the responses.
