Drill Rod/Blanks for tools
Tony - Memphis
>I saw an article in a turning mag. on how to make a small coving tool. Looked pretty handy and I'd like to make a couple of sizes to use for decorating handles and such. I tried to order some blanks from Discount Tool, but they never sent them and don't answer email The large tool companies only sell the small ones in tens. Any sources? The article said that drill bits wouldn't be hard down the shank, but I'm wondering if they wouldn't work. Its not something I'll use a tremendous amount anyway. Thanks.
Tony
Re: Drill Rod/Blanks for tools
Rick in Colgate, Wi
>Grizzly has some round HSS blanks but they are fairly short, longest being only 4 1/2" long.
John Trant (Baltimore/DC corridor)
>MSC and Enco are my favorite places to shop for steel. O-1 steel rods can be purchased in 18" and 36" lengths and all diameters.
John
Lan Brady
>Tony,
I read the same article and had to try it. I bought M2 HSS drill rod from mscdirect.com
I bought it in 36" lenghts and made several. The rod arrives anealed so you will have to harden it once you have your tool made. It is do-able using mapp gas in your propane tourch. I hade some extra 1/4" rod so I made a small bowl gouge and spindle gouge. It was easier than I thought.
Lan
>Lan I may be wrong but I don't think you can proberly heat treat HSS at home with a mapp gas torch. You can heat treat drill rod because it's high carbon steel. When I looked into the heat treating procedures for HSS several years ago it was much too complicated and precise to do at home unless you have a heat treating oven. There may be other materials and techniques that I don't know about however. If there is would you please pass these on because I would like to try it.
Bruce, a MN Galoot
>You can get O-1 drill rod from Fastenal, too, up to 36" and cheap.
Bruce
Re: Drill Rod/Blanks for tools *LINK*
Skip Strippelhoff
>Go to www.dixiepins.com
See harden and ground "Dixie Pins"
Also they have come out with new "Dixie Point Tools"
ready to use with "How to use Disc"
Good luck
Skip
http://www.dixiepins.com
Lan Brady
>John,
I am not a metalergist so I easily could be wrong with the facts. But it did work for my needs. The hss rods when purchased could be bent by hand. After heat treating, each was extremly hard and broke when clamped in a vise and vise grips. So I tempered it using the gas also. I made several 3 point tools (1/8,3/16/1/4"). One bowl gouge(1/4") and One spindle gouge(1/4").
You are probably correct with the science, but the tools worked for me.
I also bent some allen wrences and made great hollowing tools. Maybe not as good as store bought, but for under 30 dolloars total, I have quite a few usable tools.
Lan
Re: try Wholesale Tools *LINK*
Bill Turpin in WNC mountains
>They carry round, square, and rectangle M2 HSS tool bits that are pre-hardened. They are pretty cheap, too. They can be shaped or cut with grinders without ruining temper. I think they can be even bent with a torch without de-tempering. This link is for square, try a search for others.
Bill in WNC mountains
Tool Bits
Thanks all!
Tony - Memphis
