Lighting when deep hollowing
Mike Swain
>When I turn hollow forms I use a pedestal light to see what I'm doing on the inside, this gets quite uncomfortable after a while due to the heat coming from the lamp.
Does anyone use other lighting devices when deep hollowing?
Regards....Mike
Re: Lighting when deep hollowing
JKJ in East TN
>Did you try using a fluorescent bulb in the fixture? Some very bright bulbs are available now and they radiate much less heat than an incandescent bulb. I use these in various reflectors around the lathe to reduce the heat (and, btw, I haven't noticed any appreciable flicker).
For peering inside, I use a bright hand-held multi-LED flashlight.
I suppose an enterprising person could also rig up a mirror to bounce light inside while keeping the hot source at a distance. A bright light projected through an old slide projector lens should work well.
Even better would be a bundle or single large diameter plastic fiber optic. It would take a bit of optical rigging to get the light efficiently into one end, but it may work well even if not too efficient. One of the small halogen spots would be perfect, with or without a focusing lens. The working end would be small, easy to position, and relatively cool. (I say relatively - for one of our solar energy research projects we have an *extremely* bright light source feeding a fat (12mm) fiber - the light is so bright that the heat from the end will cause a piece of paper to burst into flame!)
Brad Vietje
Brad Vietje
>These are all great ideas. I remember seeing a tiny light for just this problem in one of the turning catalogs (maybe Packard ...?). It mounted on the shaft of the hollowing tool.
I can't look it up right now because my sister has all my turning catalogs with my "wish list" items hi-lited for Christmas ... Looks like I may even get gifts I want this year ! Someone ought to be able to add specifics here.
Safe Spinning,
Brad Vietje
Thetford, VT
>I don't look. I hollow by feel, stopping fairly often to take a measuement with a bent coat hanger. I usually hollow through a hole that is too small to look through anyway. If you use light wood you can put a light on the hollowing tool and you can judge thickness that way. I had varying success with this mostly because I use woods that are uneven in color which made it tough to judge wall thickness.
Another way to do it is to build one of the lazer thickness attachments. This also has a learning curve. You have to change the angle of the lazer to the cutting tip depending on the shape of the piece you are turning. To be accurate the you must be measuring 90 degrees to the angle of the wall. So if you set the lazer for the side and then try to measure the bottom you won't get an accurate reading. It really speeds up rough hollowing however becuase you can set the lazer up so it's at the cutting tip. Then you know exactly where the tip is inside the vessel.
Les Robison
>If you are a member of WOW, look at the File Cabinet for Herman de Vries Fiber Optic light design. I have built one like his plans state and it works well. There are avaiable commercial models, but they cost $300-1000. I built mine for under $100, including the cable. I tested the conept with a 12 strand plastic fiber cable using a 50 watt halogen lamp. I now have a 100 strand cable that is just under 1/2" in diameter and it transmits lots of light.
Link to Herm's Homebuilt Fibre Optics *LINK*
Mike Brazeau
>Go to Tips & Tools. Herm has some great ideas.
Mike
http://www.hdv.net/
Dick Hines
Dick Hines
>I use the painters clamp on lights for the outside and for the inside I keep a close eye on the little lazer beam.
Barry Turner
>Have you tried LED lights? Some of them are so small they could easily be taped to a tool shaft.
>Barry's idea is sound. I use a 12 volt taillight replacement bulb with a transformer to put a light on the end of my boring bar. I use this for turning thin white wood vessels. You can see the thickness from the outside. The taillight bulb will handle the vibration without blowing up.
