alcohol soak for turned boxes?
Richie
>Will alcohol soaking work on turned boxes with end grain hollowed out? Im new to turning.
Richie
Re: alcohol soak for turned boxes? *LINK*
JKJ in East TN
>Dimensional stability is critical on a turned box if you want the lid to fit. This is probably not something you want to rush! Regardless of method you use, be sure the wood is dry, or more precisely, at equlibrium with the intended interior environment. If the wood is green, I would rough turn it thick like you would a bowl, then let it dry completely before finish turning. You can weigh the blank periodically and it's ready when it stops losing weight.
Richard Raffan's excellent book, Turning Boxes, has a section on making boxes from green wood.
BTW, even turning with kiln dried wood can result in a lousy lid fit since hollowing can reveal internal stresses in the wood. Some experts recommend letting the hollowed box relax at least a couple of hours or overnight before finish turning and fitting the lid. The larger the box, the more likely the problem.
I like to turn small boxes out of dense exotic woods - cocobolo is my favorite, partly since it turns so cleanly it hardly needs sanding.(and partly since I have a lot of it!)
The link below has several good articles on turning boxes.
tek-Brunswick, Ohio
>It worked for me the one time I tried it. I put the rough box in DNA for a day. Then let it dry for a week. I think I dried it in a paper bag for the first few days and then took it out. The box was spalted beech.
Tom
Also
tek-Brunswick, Ohio
>The walls of the rough box were about 3/8" thick.
Barbara Gill, Remlik VA
>I used the denatured alcohol soak for some rolling pin blanks. I rough turned the blanks to 3" then soaked for two weeks (I was away and it was convenient to use that time period). I stood them up on end, rotating about every week. They stopped loosing weight after about 1 1/2 months if I remember correctly. I left them until I could turn this summer. Each blank was barely out of round. The rolling pins have remained stable. These blanks were walnut.
I am now in the process of drying some more shorter blanks for wine glass stems. I only soaked 48 hrs. The magnolia has cracked on the ends. The cherry and walnut are fine. It has been two weeks; they are still loosing weight.
You might want to try this technique with your blanks before turning the boxes.
Brad Vietje
>I agree with Jim on the dimensional stability part. There's no reason the alcohol soak won't help the wood dry, and perhaps prevent cracks, but don't scrimp on the moin=sture content of the wood -- for a precise fit, the wood has to be dry -- at equilibrium with the air around it.
I would not recommend soaking solid box blanks. Rough turn them green, leaving them a little thicker than the final dimensions, then soak, dry, and re-mount for finish turning, sanding and finishing. For common, end-grain boxes, the shrinkage is pretty small (depends on the species, and where in the tree the blank came from); for side-grain blanks, there will be more shrinkage, and you'll have to leave the walls thicker in roughing (and dry them longer).
Safe Spinning,
Brad Vietje
Thetford, VT
Ron in Drums PA
>Do it all the time.
Rough turn
Soak for a day in DNA
Let dry in a brown paper bag for a day.
Wrap the outside in newspaper for a week or two.
Then finish turn.
keith zimmerman, Normal IL
>I have done this several times. My workflow is:
Rough turn the box and lid
Soak in DNA overnight (at least 2 hours, minimum)
Drip dry
Wrap in grocery bag paper leaving the inside of the box and lid exposed to the air.
Finish turn when dry.
Richie
>thank you all for your help
