Have a question? Ask Woody!
Looking for a new bandsaw
Mike Cunningham
>Does anyone here have the Grizzly 17" heavy duty bandsaw? If so I'd like to hear your opinion and overall impression of the machine. I'm not interested in hearing about the smaller Grizzly bandsaws, I have one of those. The machine that I'm interested in is the Model G0513 17" throat, 12" height, 2 hp. In particular I'm interested in hearing about it's power, is it sufficient for resawing 6"+ stock and how about cutting bowl blanks. How's the fit and finish, diod it require a lot of adjusting and tweaking? Does it continue to require adjustments? I'd alo appreciate hearing from owners of the bigger Rikon and the two Jet 16" bandsaws, the Model 708749 and the 710750. Same questions on those saws.
Thanks very much!
Mike in Cape May
Re: Looking for a new bandsaw
Ed Kelle
>I got that Grizzly just for those reasons. I have been very happy with it. Cut lots of blanks on it with no problems at all, I even have cut up to almost the total resaw height. I use a Timberwolf AS blade for green wood, it is 3tpi. I've made a circle cutting attachment for cutting my blanks and this helpa very much. I only wish the table was slightly larger but I support my jig on the outside by clamping some blocks to the outside of the table. I think the price on this just went down to $795 which is a great deal for this.
I did notice that on the lower rear bearing, it is slightly difficult to get at, hard to get an allen in there, and sometimes it does have a tendancy to drift backwards as well, though that issue could be my fault due to how hard it is to tighten in this area. I remove the lower bearing guards because they make it impossible to adjust the bearing guides.
I really do not have any complaints with the saw, I thought the quality is quite good and their customer service is great as well.
Mike Cunningham
>Thanks Ed!
Earl Eyre
>I don't have one but one of my best friends does. He doesn't do turning but builds furniture--lots of it. He uses it mainly for fairly heavy duty resawing and says it runs true, never bogs down and has had no problems. He makes all of his own 1/4" panels by resawing so it gets use, usually at the maximum depth. He even resaws lots of logs that he gets with no problems.
Earl
Re: Looking for a new bandsaw *LINK*
Juergen
>I've heard good things about the RIKON saw. It has some features not found on comparable Delta, Grissly, or Jet saws.
http://woodcraft.com/family.aspx?familyid=5220
Tool_Addict
>Bought that saw a few months ago. have used the heck out of it for bowl blanks, resawing etc. Really happy with the power and performance of it. Took the time to set up a TW blade, and make a light correction for drift in the fence. Guides stay in place. Would buy again no question.
Mike Cunningham
>Thanks for all of the replies, they're very helpful!
Guy
>I have the Rikon and to me they are like Grizzly (had a Grizzly 14 incher for a long time). They aren't fancy but are good solid tools that just keep on running. The motor is strong and adjustemts are easy enough. To me it is a very solid saw. I love the cast iron wheels and large table. I looked at Laguna/Minimax and frankly I couldn't justify the extra cost which was double or more. The Jet/Delta are really no different than the Rikon and cost more also. I don't have any brand loyalty to any company. All my big tools are different brands. Either way I don't think you can go wrong with the Griz or the Rikon. Good luck!!
