Cleaning up epoxy messes
Brian Hahn in SW Wisconsin
>I was working with epoxy this morning and thought I'd pass along this information about cleaning up epoxy.
Acetone: Many people use acetone and it works reasonably well. But it always evaporates too quickly for me and I'm not particularly fond of the odor. Plus it dries out my skin.
Denatured Alcohol solvent: Works better than acetone for dissolving partially cured epoxy. It doesn't evaporate as quickly, so I can use less to get the mess cleaned up. And it's a lot easier on the skin. I've used it to clean epoxy coated brushes even after the epoxy has set up. BTW, this explains why glue-blocks that are attached with epoxy come off when the bowl is soaked in denatured alcohol. Epoxy can take a week or more to fully cure.
Isopropyl Alcohol: Rubbing alcohol from the first-aid supply section of the drug store or grocery store. Often it is available both as 70% Isopropyl Rubbing Alcohol and as 91% Isopropyl Alcohol. These work even better than denatured alcohol. The price is reasonable and it doubles as a first-aid antiseptic when something else goes wrong.
Re: Cleaning up epoxy messes
George Van in WI
>Thanks for the information Brian, I have to fill some voids with epoxy and will have the alcohol ready! I too dislike the smell of acetone.
John in Kerrville TX
>I use plain white vinegar, but then I only clean it up when it is still not cured. It has always worked though and I think this came from West System Epoxy.
john
White vinegar
>Brian,
I have been using white vinegar for years and years to clan epoxy before it sets, it does the job very well it is not flamable and there are no fumes, give it a try.
A quart goes a long, long way.
mis dos centavos
Jorge
Ric Taylor
Be Careful
Ric Taylor
>Someone mentioned in a post here earlier that acetone can cause liver damage when absorbed through the skin. I use acetone to thin down sanding sealer, and since I read that post, I'm careful to have rubber gloves on.
Ric
Re: Be Careful
Dave Winters, Steamboat Springs, CO
>Definitely on the acetone. Any solvent that is that thin can be absorbed through the skin. I always think of it this way: I wouln't want to drink acetone, wouldn't want to get any in my eyes, don't want to inhale concentrated fumes, therefore, I'm wearing gloves.
Re: White vinegar
>Thanks, I'll have to give that a try next time. Although I wouldn't call vinegar odor-free. (Try making pickles with a hot vinegar and salt brine sometime!)
Re: Be Careful
>Also, prolonged exposure to the fumes can be just as bad.
That's one of the reasons I prefer the alcohol.
