REAL MILK PAINT
Help!!! Roughing Gouge getting Caught By Grinder
Bart Goldberg
Bart Goldberg
>I have the Wolverine sharpening jig, and on two occasions, my roughing gouge has gotten caught by the grinder. It scared the dickens out of me when it happens. I dressed the wheel to make sure it was smooth too. Anyone ever experience this. What am I doing wrong that this is happening? I have an 8" slow speed grinder from Woodcraft and I'm using the softer of the two grinding wheels.
Thanks
Bart
Re: Help!!! Roughing Gouge getting Caught By Grinder
Trying to take too much off in a single pass?
Garrett in Victoria
Bart, are you just above the center of ...
TDaniel
>the wheel? If so the tool is getting pulled down against the wheel and "toggles" ( like the locking mechanism of a pair of vise-grip pliers). At toggle position the mechanics have an infinite amount of mechanical advantage and it will overpower you. Try a little higher on the wheel.
Bart Goldberg
Bart Goldberg
>I think my problem is the angle of the grind. It appears to be about 60 degrees. A bit to shallow perhaps, that's probably why its catching. I'm not sure what the angle of grind is for a roughing gouge, but I suspect it should be closer to 45 degrees. Here's the other problem, the wheel is badly gouged. I've attached a picture. Is this able to be saved, or is it time for a new wheel?
Thanks
Bart
Say Bye Bye to that wheel
Dustmaker Mike
>I would not trust a wheel with a nick out of it the last thing you want to happen is the wheel come apart.
Got bounced
>Bart,
Sent an e-mail, got bounced by patmedia.
Tried again . . .
Mark
Re: Got bounced, Again
albertabob
>Two things Bart:
1. Your angle is too low vs the height of curvature of the wheel and the tip of the blade.
Pull the carriage in a bit and try to get the tool riding about 1/2-34" up from the equator of the wheel. ( 8 incher)
2. Get a star wheel dresser and pull back the tool rest that came with your grinder so that the dresser notch fits in the back of the tool rest. (closest to the stone)
Now move the rest close to the damaged stone till it just touches.
Turn on the grinder and tilt the dressing wheel into the stone.
Take off about a 1/16" at a tine.
Reset the tool rest and do it again until the nick is gone.
Cheers
Bob
Ric Taylor
Be Careful
Ric Taylor
>Bart,
In an earlier life, I was an Air Rescue pilot in the Air Force. I had several missions out to ships at sea to pick up crewmen who had pieces of grinding wheels lodged in their faces. Ever since then, I have had a really healthy respect for grinding wheels. After having a serious catch such as you experienced, I would be afraid of hidden cracks in the wheel. I would toss it.
Ric
Wheel with a chip is suspect ! !
Pete in Holland, MI
>Remove the wheel and stick the shank of a screw driver thru the hole to support it. Tap the wheel with the butt of another screw driver. It should ring. If it doesn't, it's cracked and EXTREEMLY dangerous to re-use. As mentioned in other follow-ups, grinding wheels don't fall apart while running. They explode and will do you and your equipment a lot of harm.
