CA accelerator
Mark Kauder, Phenix City, AL
>I notice that Acetone is a major incredient of CA Accelerator. Just wondering if Acetone alone would work? - much cleaper.
Anyone ever try it?
Mark
CA accelerator
Anyone ever try it?
Mark
Re: CA accelerator
Jim Shaver - Oakville, Ontario
>Hi Mark,
As I have been told, the principle in an accelerator is to cut the CA off from oxegen, and acting as a barrier so the CA will set up quickly. I have even been told that water would work, but H2O has oxegen in it last time I checked..
Trial and test may be the best way to go on the acetone, and you can remove nail polish too, I am told.
take care,
Jim
Re: CA accelerator
Barbara Gill, Remlik VA
>I thought the acetone was in the dissolving agent. I don't smell acetone in my accelerator.
Re: CA accelerator
Eaglesc
>I have used some accelerants that smell ike acetone others don't
I never use it while finishing pens but while doing glue ups I have used ammonia or alcohol.
Re: CA accelerator
>Mark It's way the hell to early in the morning and I'm headed to the shop. I'll do a test and get back with you later this morning. Ijust happen to have both. I've tried water and Ive tried baking soda and water, they both work but not nearly as good as accelorator.
Re: CA accelerator
>Mark Interesting experiment. Basically Acetone doesn't work any better than spitting on it. Maybe I'll ask my friend who chews to spit on it and see if that works any better.
Re: CA accelerator
JKJ in East TN
>You might try looking up an MSDS. From one source I found this data for Hot-Stuff Cyanoacrylate Accelerator:
98-99% Dichlorofluoroethane (CH3CC12F) HCHC-14lb
0.15-0.16% "N,N-Dialkyltoluidine"
0.002-0.003% Organic Fragrance, Proprietary
0.002-0.003% "2,6-DI-tert-Butyl-p-CRESOL"
Re: CA accelerator
>I know this is a tangent to your question, but if you are not using the spray ans of accelerate, try them. Much better than those D@#$^% little spritzer bottles. OTOH, if we could find something really cheap to put in the spritzers we might be on to something.
JKJ, I really wanted some of that fragrance and its proprietary! I'm bummed.
Re: CA accelerator
Carole in VA
>I was watching a Dave Hout last night and he just used a spritz of water as an accelerator. Can't get much cheaper (or user friendly)than that. I have not tried it though.
Is CA Accelerator That Expensive?
Barry Turner
>How much are we gonna save here by trying to find an acceptable substitute for accelerator? How much CA are we going to waste along the way? I don't remember it being all that expensive. Why not just buy a really big bottle of the real stuff?
Re: CA accelerator
Eaglesc
>"How much are we gonna save here by trying to find an acceptable substitute for accelerator? How much CA are we going to waste along the way? I don't remember it being all that expensive. Why not just buy a really big bottle of the real stuff? "
Go ahead and do that if you wish,the"real stuff" aerosol is $12.00 a can at my local supplier 70 miles round trip or $8.00 from a Klingsoprs but they are even farther.
"I know this is a tangent to your question, but if you are not using the spray ans of accelerate, try them. Much better than those D@#$^% little spritzer bottles. OTOH, if we could find something really cheap to put in the spritzers we might be on to something."
Try alcohol or amonia if you just want to spray it so it doesn't stick to anything.
I use a lot of CA in my pen blanks and sometimes you just run out.
The down side of the spritz bottles is if you don't put the clear cap on the stuff evaporates.
As far as how much do you use?
This inlay had 120 pieces put it in.
I still try to keep commercial on hand, I never use it while doing a CA finish, I use the substitue when it isn't critical.
I even recycle CA while sealing the insides of pen blank glue ups and the ends.
I don't mind saving money or not being inconvenienced of running out.
It isn't just the cost of buying the stuff, these days gas is still high.
Amnonia and alcohol I have on hand am I am not crazy about spraying water on wood.
The alcohol especially dissapates quickly.
Re: CA accelerator
>Thanks to all for the input.
The main reason for asking, was I was setting at the computer at work and happend to have a nearly empty bottle of the accelerator on the desk (don't ask) and noticed it showed Acetone and some aromatic something as the only two components.
I use lots of CA for one thing or another around the shop. I buy it cheap direct from the wholesaler, buying 16 oz bottles. Same goes for the accelorator - using a big spritz bottle.
I use Acetone as a thinner for NC Lacquer when the weather is cool, so I have gallons of it around the shop already. So it would be one less thing to have around the shop, and many factors cheaper.
Just wondered if anyone had tried it, before I tried it.
Thanks again, gang.
Mark
Re: CA accelerator
Michael Serpa
>Acetone is a cheap substitute for DEBONDER not ACCCELERATOR! I use it for clean up.
Re: CA accelerator
RussFairfield
>The only thing that I have found that works as well as the commercial accelerators is Freon. I see the post that lists the ingredients as being over 90% a flurocarbon. What is freon? A flurocarbon.
There are a lot of things we can use besides the commercial accelerators. None of them work as well, and some of them are so slow that the CA by itself is as fast. Water is one of those. Any alkyline solution will accelerate the cure of a CA glue. That is why hard water works better, and therefore adding baking soda to the water also works better.
The myth about water working is because the CA needs some moisture to cure, and the atmospheric moisture or the residual moisture in the wood is usually sufficient. That is why bone-dry wood has to be wetted before the CA will do anything. However, it doesn't follow that just because a very little water vapor will work, flooding the surface with water is even better. The bigger problem is that the water will cause more problems with the wood than anything it can do to accelerate the cure of the CA glue. For one thing, the water will penetrate into the wood in the area of the glue and CA glue doen't bond very well to wet wood.
Cellulose also works as a mild accelerator, so if Mark were to add some nitrocellulose lacquer th the acetone, it might work as an accelerator. Use straight acetone if you want to soften the CA or a DE-cellerator to extend its time to cure.
As Eagle has noted, any alcohol is a better accelerator than water, but not as good as the commercial products.
I have found that the spray cans are the less expensive way to use an accelerator. They cost more, but I use a lot less, there is no evaporation, and the pump doesn't die before the bottle is empty.
The problem with accelerating the cure is that the CA glue is a stronger and less brittle bond if they are not used. That is reason to not use acceperators.
Re: CA accelerator
Lan Brady
>Mark,
I use Alcohol as the accelerator. It is not quite as fast as the commercial brand, but it is nice having alcohol nearby for the cuts and abrasions that I seem to end up with.
Not much of an answer to your original question, but my opinion.
Lan
Re: CA accelerator
Eaglesc
>Not politically correct but cigarette smoke is also an acellerator.
I have aDC boot right behind the mandrel on my lathe.
I noticed once While I was waiting for some CA to dry while hardening a blank the smoke was going right past the blank.
Instant set.
If you don't think acetone will set CA try it. It does.
Also if you fume purple heart wwith muriatic acid it will turn a beautiful cranberry color but CA won't stick to it.
CA will grab wood with different PH's but doesn't like acid at all.
DAMHIKT
Re: I'll be.......
RussFairfield
>Eagle,
After all of this conversation about acetone, I went out to the shop and put some acetone in a spray bottle. AND IT WORKED, The only problem was that it melted the spray cap on the bottle. Then I tried a couple bottles that had come with accelerator in them. Now I have 3 spray bottles with melted pumps.
And I am wondering why it didn't work the last time I tried it.
I have heard that about cigarette smoke.
Re: I'll be.......
Eaglesc
>Russ it's funny you mentioned the pumpd disinintegrating.
When I first started turning /pens or anything for that matter, The people at WC tried to sell me everything under the sun.
Little did they know I didn't have any money.:>).
They suggested I get some accelerator.
At first I didn't. but on another trip I did.
When I got home I opened up their bottle of accelerator and realized the smell was familiar. The light bulb went off and I realized I just bought acetone at the rate of over $$100.00 a gallon.
I closed their bottle and brought it back the next trip.
I refilled a pump bottle with acetone and got the same results that you got.
Their are different suppliers and I imagine they all have their own formulations.
When I buy Accelerant I try to use the brand that I have in CA.
It doesn'e always work out that way, but then again there's always ammonia.
Re: CA accelerator
Greg Jensen
>It is one of those small ingredients that does the work. I forget which one. The active item is in such small quantity that there is only a few drops in a bottle. That active ingredient is very expensive and is only needed in that small quantitiy. Thats why they thin is with solvent to reduce the price.
As a side item. The acetone accelerators work well as a debonder. Just apply the acceletaors heavily and it will desolve the CA.
Re: I'll be.......
>Russ I probably should have clerified my test. The CA did harden but for my real life test I put glue on one piece put accelorator on the other and held them in place for 30 seconds. The CA accelorator held the Acetone did not. Then I tried it at 20 seconds, both came apart but you could tell the CA with accelorator was trying to bond.
Denatured alcohol
>Mark
I don't like to breathe the accelerator, so I filled an empty spray bottle with denatured alcohol, it works well. a caveat, I don' remember what brand my CA was, and never had trouble with it, now I am using Balsa and it works, but it gets a white top layer, so I have to do another slight cut or sand to get ride of it.
Jorge
Re: CA accelerator
>I finally got out to the shop, and you know what, the back of Debonder bottle and the Accelerator are printed identically, except for the barcode.
Looks like a mistake on their part.
Mark
Water as accelerator
Earl Eyre
>Water works great. I used that for years in other kinds of projects when I would just buy CA at the hobby store. Main problem is that it will usually turn the CA white. So if it is in a hidden joint, no problem. But if you are filling exposed fissures or stress joints, or mixing CA with turquoise, coffee, etc. it can leave an ugly whitish tint that is impossible to get rid of.
Earl
Re: CA accelerator *LINK*
Juergen
>I Googled the main ingredient and the ONLY item returned is the MSDS at the link below.
http://www.mohawk-finishing.com/mhk_cds/product_msds/m745-3542-%203543-%203544.pdf
Re: Water as accelerator
Ric Taylor
>Earl,
The reason it turns white is because it has crystalized, which results in a much weaker bond. Because of that, I don't use water.
Ric
