Have a question? Ask Woody!
Ungluing?
Ungluing?
Ungluing?
>Anyone tried using the release agent for CA for intentionally dissolving a joint. (Not just removing your finger from your eyelid.)
I was thinking of turning some half or quarter columns. Glue either two or four pieces together and then turn them and separate them by using the release agent. Would it have to soak forever?
How do you turn and then separate pieces? I need to leave nice clean edges and don't want to rip them and lose a saw kerf. TIA
Re: Ungluing?
Re: Ungluing?
Carol Reed, the Router Lady, Dubuque
>Next time you get groceries, Barry, ask for paper instead of plastic. Sandwich that between the pieces when you glue them. I use the regular yellow woodworker's glue we all use. When you are done turning, a thin knife inserted in the paper joint will undo things for you. Scape off the paper residue (minor job) and you are good to go.
Re: Ungluing?
Re: This world is changing...
n2wood
>I've used old newspaper for this and it works.
Seems that the paper will seperate and leave a little on both halves. A little easier to come by than paper bags any more...
Re: Ungluing?
>I use newspaper also. I find that sometimes scraping the paper off is dangerous if you have a fine detail on the edge of the piece you can chip it off. I use a cabinet scraper for most of it, then switch to a carpenters chisel used like a scraper for finer details and then If i have to I use white vinegar to soften the glue and get all the rest off.
Most of the time for furniture this isn't necessary. Just scrape the paper off and glue the piece on. However on some pieces I made that needed to be flat, finished and sanded on the split joint I had to resort to the extreme measures above get all the residue off.
Re: Ungluing?
>Something I have always wanted to try is to sand it off. I have a huge piece of sanding belt from a large oscillating belt sander. I got some from a guy that makes boxes. He glues a large piece to a piece of MDF (nice and flat)and sands his boxes so they stand perfectly flat. Since it is so big, it might work for split turnings. I just haven't had a chance to try it. Should cure chip outs from scraping. Hmmmmmmmmm........
Re: Ungluing?
>About the paper grocery bags. Dave Smith taught me to ask for them at the store and stockpile them to wrap DNA soaked bowls to control drying. So I got in the habit. I have a nice little stash of them and still reply 'paper' when given the choice.
Re: Ungluing?
RussFairfield
>The only problem with using newspaper is that the glue has to be used sparingly. Otherwise it will soak all the way through the paper and it will be difficult to impossible to separate. For us who are heavy handed with the glue bottle, the grocery bag paper works easier because the glue doesn't soak all the way through it.
Re: Ungluing?
>I have a 4 x 24 belt sander turned upside down and use it to sand many things. I am either more persnickety than I used to be or demanding a little more in accuracy. I find many of the things i sand by holding them in my hands on the belt sander to be a little lopsided when I get through. Your idea of sand paper on a flat surface may be better.
Re: Ungluing?
Re: Ungluing?
Dennis Daudelin
>I prefer to not try and unglue.
I purposefully make the piece longer than I want. I glue only at the ends and when I'm ready to flip the pieces, I just cut the end off.
I find that this saves a lot of time and is very easy to do!!
Dennis
Re: Ungluing?
>Barry It's better but still not perfect. I try to use a sanding belt fastened to my workbench to flatten half of an inside out turning before I glue the 2 halves together. If you have to make more than just one or 2 passes you still get a slightly convex surface. I try to keep everything as flat as possible when I sand but still get a very slight convex surface. The more I sand to get rid of it the worse it gets.
I trued using my friends 6" belt sander and that works well as long as you do it accurately and carefully. The problem is it will also ruin it really quickly if you screw up. To really flatten these things I've found that a cabinet scraper is the best method. I use it like you would a hand plane. I pull a straight edge across the piece and mark all the high spots. Then I use the cabinet scraper to flatten them. This also works well for removing glue if you need a really accurate/flat surface.
Re: Ungluing?
>True Russ but I've been pretty sloppy with my glue and still not had a problem. One weekend I tried a bunch of papers because people always suggested brown paper but I never had any. I tried water color paper, newspaper, brown wrapping paper, paper sacks and several types of drawing, drafting paper. All worked well except the water color paper. That stuff is tough and doesn't want to split. I do think a thick brown paper is probably the best but it was pretty close between all the papers I tried. My suggestion, use whatever you have but if you have easy access to brown paper go for it,t's been proven to work.
Re: Ungluing?
Re: Ungluing?
RevDoug
>A heat gun or even a hair dryer works very well. The glue will soften and release long before the wood gets hot enough to burn or scorch. Works everytime.
Turn 'em round,
Re: Ungluing?
Roger H
>Interesting. 50 plus years ago I recall using newspaper and "white" glue for split turnings. Of course grocery bags were not that plentiful in the rural areas--we raised most of our food. Most communities had at least a weekly paper or gossip sheet.
