Inside out bowl?
>Can you turn an inside out bowl? That is, glue four square blocks together, turn a bowl, take them apart and flip them like you do for ornaments, etc. I can't visualize whether it would work or not. I think not.
Inside out bowl?
Re: Why not??
RussFairfield
>Don't give up so easilly. There is no rule that says that an inside-out turning has to be turned between centers and with closed ends.
There are some interesting things that can be done with "double turning" and open forms. Vases can have wings. Bowls can have shaped openings without having to resort to drilling, sawing or carving tools. And, the open form of a bowl or vase allows you to go back and hollow the inside after the openings have been shaped with the double-turning. There are endless possibilities to explore.
Re: Why not??
ken chase
>inside out turning is a technique I'm not familiar with. Can you explain please.
Re: Inside out bowl?
>Barry I've done an inside out platter. I found an article somewhere that had that. I may have a copy of it somewhere in my handouts for inside-out turning. I also have an article on turning an inside out vase with an open top. This would be exactly the same as an inside out turned bowl except taller. I'll try to look and see if I have those articles later today.
It's been done with success
Brian Hahn in SW Wisconsin
>I've seen pictures and articles about inside-out or cut-them-apart-and-reglue-them bowls. It creates some very interesting shapes. But I don't remember where I saw the articles and pictures. Probably have the information on my book shelves...someplace...
>Thanks Guys. I was trying to figure a way to turn something that would end up looking like a pagoda roof, but I just drew out a sketch of a bowl. If you turn the inside only, you could reassemble the four blocks, but would come up with a sort of cross in the middle, not what I had in mind.
Bob Lemon Sacramento Ca.
>Barry, One of our turners showed an inside out bowl at a meeting. He also brought in a display board showing how it was made. It has 8 diamond shaped segments. The segments were glued together with paper for easy separation. As the picture showed, he also had band clamps while turning. At the left side of the display board is the resulting bowl. It makes for a very interesting turning.
JKJ in East TN
Barry,
How about turning away some of the outside after assembling the blocks? (picture below, left)
For more fun, pop the second turning apart and reassemble to the original orientation. If careful with the grain, the seam might be hard to see. Then you could finish turning the outside of the bowl - let them figure that one out! (3D modeling seems like a good way to interactively experiment with such ideas before going to the lathe.)
