Liquid Wrench, WD-40, or ???
RussFairfield
>I may be old fashioned, but I still use a little 30W motor oil mixed into a lot of Kerosene. About 1 part of the 30W in 5 of kerosene is about right, but I never measure. If I don't want tne oil residue as a lubricant, I use straight kerosene.
It works as well as either of them, and is a lot cheaper. Only problem is that it doesn't come in a spray can. If kerosene were invented today, it would be advertised as a "Miracle product with 1000 uses" because it could replace almost all of the special cleaning and lubricating stuff we buy.
Someone once told me, "But WD-40 has Benzine in it?" So does Kerosene, last time I looked.
Re: Liquid Wrench, WD-40, or ???
If it is REALLY stuck use...
TDaniel
>iodine. Some of the Rust-Buster products contain iodine as the effective ingredient.
Also makes a good cleaner...
Rod Peterson -- Ormond Beach
>> �a little 30W motor oil mixed into a lot of Kerosene. About 1 part of the 30W in 5 of kerosene is about right�
�for stainless steel. That's what we used in the shipping area of a place I used to work many, many years ago that made stainless steel steam cleaning machines for hospitals and labs. We put together a set of instructions, stamped a serial number on an adhesive tag, closed it all up, then cleaned the whole exterior with that mix. It put a nice shine on the SS, not to mention removing all the finger prints from down the line.
Ironically, after being away from South Florida (where I grew up) for >30 years, I wound up living for four years in a condo not a block away from that same plant�although they're in a different business now.
Rod
JKJ in East TN
I believe you're right. I never let my kerosene can run dry. Just don't buy it off the shelf in a store unless you have more money than you need.
I use kerosene as a coolant/lubricant when drilling steel. It's good on oil stones for sharpening. Others mix it with chainsaw bar oil and use it instead of water to lubricate bandsaw mill blades. And I just serviced my tractor last weekend - Kubota requires the diesel fuel filter be cleaned with kerosene.
Next thing you know, people will be boiling bowls in kerosene.
Kerosene
W.C. Turner
>Anybody ever use it on a cut?
I've used it for all kinds of cuts since I was a kid.
But, back then, we called it "Coal Oil".
As soon as you sustain any cut, if you'll slap a rag full of kerosene on it, it'll never be sore.
I've had Doctors give me the strangest looks when told that I used kerosene on cuts. They frown on this cure.
Another Kerosene Use
Clem Wixted
>I inherited my father in law's workshop. Sometime in the early 50's he put some screws, nut and washers as well as a jacobs chuck into glass jars with a little kerosene (range oil) in the bottom. These items are as good, or better, than new. Not a hint of rust and as shiny as the day they were made. So, if you need to keep some washers for 50 years, put them in a glass jar with a litle kerosene :-)
Clem
Yep
TDaniel
>My grandma always used kerosene on our cuts. We would have a choice (sometimes) of that or iodine. Boy, was I glad when Bactine came along!
TD
Don Henthorn
>Back in the twenties we kids often woke in the morning struggling for breath because of what was called the croup.Our parents would give us immediate relief with a few drops of kerosine in a teaspoon of sugar. Amazing how quickly it worked.
40's too
TDaniel
Re: I used Kroil today for the first time since
Dale Stansbery
>I can't seem to find Liquid wrench in liquid form any more. It was on a severly stuck bolt on a power steering unit. After an hour or so it finally broke free, I believe thanks the Kroil. It's probably kerosene based as well.
Re: Kerosene
RevDoug
>I worked for a couple of years at a gas station. When we got a small cut, we would discharge a gas hose over the cut. It would usually be healed over the next day.
Turn 'em round,
Jim King
>Here in the Amazon Kerosene or diesel is used to put on animals ears to keep the vampire bats from sucking the blood out of them. Also mixed with used oil it is the best cure possible for mange in animals. Just give the animal a bath in half kerosene and half used motor oil and the mange is gone and the dog or whatever animal looks like new in a couple of months full of new hair.
same here Jim
TDaniel
>We used to have lots of hunting dogs when I was young. Someone gave us a high dollar bird dog once that was covered with mange. I was given the job to mop the dog every day with a mix of kerosene and used motor oil and sulphur. After a couple of months it was a beautiful dog again and the best pointer we ever had. You can also use the same mix to keep fleas out of the doghouse...just mop it across the doorway.
Re: same here Jim
RussFairfield
>And Kerosene is good for removing soap scum and the ring in the tub.
Uses for Kerosene in the shop.
RussFairfield
>Kerosene is a good thinner for oil and varnish finishes. It takes a little longer for the oil finish to cure than with the Mineral Spirits, but this can be a good thing in very hot or dry weather.
A few drops of Kerosene in a lacquer will slow the evaporation of the thinner and reduce the tendency for blushing.
It is good for removing pitch from saw blades and router bits. It is slower that the commercial products, but a lot cheaper, and there is no problem with damaging the blade or bit. There is evidence that extended use of the commercial cleaners will damage the solder that holds the carbide to the steel. An overnight soak in Kerosene is harmless.
It is a good lubricant for the sliding things, pivots, and screw threads under the saw table. It leaves enough of a residue to act as a lubricant, but not so much that it collects dust.
An application of Kerosene on the ways of a lathe will keep them slick and shiny.
A little Kerosene into the scroll of a chuck will remove the trash the collects, and leave behind enough lubrication to resist wear, but not enough to get gummy or collect dust.
