Ancient Pottery of My Mind -- comments welcomed
e
>Having such a strong attraction to American Indian pottery, i have been drawn to the fine-line pieces displayed in books and museums. The pieces that showed wear and history were most inspiring.
Over the year, several pieces have been turned and embellished with this design. While they did an adequate job in representing this type of pottery, they were not what i saw in the ancient crevices of my mind ...
It took months to finally understand what i wanted ... and that was to merge my attraction to ancient pottery with my WOOD turnings. This piece moves closer to my vision.
The outside of the vessel is bleached and then the fine-line design is burned in. The final step is to carve away the missing slip and bring the wood to the surface.
Re: Ancient Pottery of My Mind -- comments welcomed
Steven Antonucci
Wow.
Steve Antonucci
>Real nice. I like the carving to "bring out" the wood.
Ed Karch in No.VA
>What Steve said!!!
That looks like a muse/voice/style definer piece.
Ed Kelle
>I like this a lot and can relate to your way of thinking.
Looks like you did a great job of carving away to the wood level. Is this all done by hand? I'm sure it took a ton of sanding to get the finish so nice.
Any thoughts of bringing color to the pattern? Maybe some muted washes to give the appearance of time worn color?
Really nice piece!
>Now your on to something. I really like this. Good execution and good imagination.
Molly Winton
>I agree, WOWSER. This is beautiful. It says so much by uncovering what's beneath. This is wonderful e.
David Breth
>Patience, thy name is "e". That piece is just flat out gorgeous. I kind of get the feeling there might be a few more of these in your future.
>Exquisite!
Your imagination looks into places I could not go. I really like the way you darkened the cliff faces of your mesas to further separate the two surfaces. Is the wood cherry? In any case, its color reminds me of desert Navajo sandstone, which also fits your theme.
Did you mark and burn the entire upper surface before you decided how much to carve away to the lower level? :^) On a more serious note, I have a technical question: How did you control the depth of the carved areas? I guess that's not so important, because I can think of three or four ways to get it done.
Jennifer@Indy.USA
>This is awesome -e-! I only wish I had thought of it first :)
A very unique and wonderful way to show interest to both the Native American form and the natural wood below....I just Love it!
What a great design concept!
Jennifer
JamieDonaldson
>My first response is WONDERFUL, and then I thought of it as a Trent Bosch piece in reverse! J.Paul Fennell has a similar concept with the basket weave sections exposed under the outer surfaces, and I like them all.
Mark Kauder. Phenix City, AL
>-e-
This is a stunning concept, and a Fantastic execution of that concept. Like others, I am blown away by it.
Mark
e
>you have arrived!
and now that you know the way I can hardly wait to see what comes out next.
Congratulations!
and thanks for sharing it.
Jorge
Wonderfully NEW!
Ruth Niles
>e, I love your concept and it sure is original. Keep up the fantastic work.
Keith Tompkins
Keith Tompkins
>Hi -e-, Yes, this is an emotional piece.....a breakthrough? Nicely done!
thanks for the feedback!
e
>thank you all for taking time to post.
i really had no idea how this piece would be received...sometimes it's good to get outside my vacuum.
Re: thanks for the feedback!
Les Robison
>e, you never mentioned how you removed most of the wood for the lowered portion of the piece. Did you use a drill with a set depth, a router, a powered carver, or just do it by hand?
oops-the answers ...
e
>everything is done by hand & eye! the wood was turned, bleached, and fine-line embellished -- then areas for the missing slip were selected. i found that i couldn't visualize the carving unless the piece was uniform...but perhaps this will change in the future.
using my woodburing mini-skew tip, the outline of the area to be carved was burned in. this roughly sets the depth and gets a nice clean, seared edge. plus i had more control with the burning tip than with a cutting tool.
using carving gouges, i roughed out the carved area being careful to not go too deep. the surface was sanded even and any fine adjustments to depth were made using the outer curve as a visual guide. i just kept adjusting the inner curve to match.
then it's just a lot of detail work, such as defining the carved edges and not destroying them with the sanding. and then there's a lot of wet sanding.
the photo makes the bleached wood look much whiter/brighter than it is -- i tried to sand through some bleached areas to get a more worn appearance, which photo doesnt show. i hadn't thought of adding color...but maybe tomorrow.
as for the type of wood, it's some type of 'volunteer', urban, california hardwood 'mutt' tree ... the trees had been knocked-over by a D-8 cat so i only saw the trunks and root-balls. don't think it's cherry--we don't get too many cherry volunteers here! but it sure does finish-up like cherry.
hope i haven't missed anyone's question ...
e
Jim Shaver - Oakville, Ontario
>Hi e,
What creative insight you have to enhance the design with a wonderful sense of process. I really enjoy this piece.
take care,
Jim
Totally over my head....
TDaniel
>but I like it!
TD
Joe Herrmann
>I couldn't see the photo at work yesterday but I made sure that I looked for the message this morning at home. The comments were right on the money. Very nice!!
Joe
Steven Antonucci
Eucalyptus?
Steve Antonucci
>hard to tell from the side grain, but that was my next guess... after cherry.
Steve
P.S. Wow.
Re: Eucalyptus?
e
>definitely not eucalyptus, camphor or black acacia ---
Fantastic !
Pascal Oudet
