Stump to blank
Pat
>Any tips on cutting an oak stump into a blank for a bowl. The stump is about 10" diameter and about 18" long. This is my first attempt to turn a bowl from green wood, any help would be appreciated.
Stump to blank
Pat
Re: Stump to blank *LINK*
Jennifer@Indy.USA
>Hi Pat,
There is a really informative article on this subject on Bill Grumbine's website. Lots of pictures to go along with it too.
Jennifer
From Log to Bowl Blank
Re: Stump to blank
adrien
>If by "stump" you are referring to something with roots, dirt and stones tucked away inside, then powerwashing the detritus away so you don't ruin your tools is a good idea.
Re: Stump to blank
>I am no expert, but I did one stump, a maple toppled in my yard buy a hurricane. The stump was about sixteen inches just at it came out of the ground. I cleaned it as best I could and cut it up with my "old" chain on my electric chainsaw. I had tried power washing it, but that was like taking a mud bath. Wear eye protection! Eventually, I got it cut down to a size I could mount on my lathe and made a almost hemispherical bowl. There saw sand and dirt embedded in it. It was take one pass and sharpen the gouge. The top or opening of the bowl would have been level with the ground if you had cut the tree off flat to the ground and the bowl reached down into the root ball. Ball being the right word. The roots sort of wrapped around it. The wood in the roots was very different from the wood in the log. I also made a pair of about 15" bowls from the log just above the root ball. I would post pictures, but they are in a gallery trying to sell them to make money for Katrina victims. You would expect this to be an end grain bowl, but the grain sort of disappeared in the root ball. I am eyeballing a walnut stump next.
Re: Stump to blank
Brian Hahn in SW Wisconsin
>I've power washed a few stumps. Full foul-weather gear and a full face shield - with windshield wipers!! And there will still be stones and dirt buried in the root ball. Helps to have extra gouges - use them all, then sharpen them all at the same time.
Re: Stump to blank
JKJ in East TN
Pat,
Some of the best figure I've seen in red oak has come from the very base of the tree - it's somtimes like a huge burl.
Assuming you have a cylindrical section of the butt log (and not the root "ball"), one way is to cut the log in two down the pith, cut a cylindrical blank from each half with a bandsaw, and make two bowls. It is best to cut away the pith, or at least cut it out of the bowl on the lathe.
Often people turn the bowl extra thick, let it dry slowly for a few months, then turn it again to final thickness and surface. This minimizes warping and cracking.
I made a quick illustration of a couple of ways to position the blanks in a log to get a reasonable sized bowl, the upper one a natural edge bowl. If the bark is sound, a natural edge bowl with the bark can be quite nice. BTW, there is a book worth getting called Turning Green Wood.
