Swan Neck Hollowing tool question
Vicmarc.fan
>Why do you put only the straight part of the tool on the rest?
Ron
Re: Swan Neck Hollowing tool question
Mac
>Because the straight part is the part that lines up with the cutter,if you put the bent part on the rest,the cutter is way beyond the center line and it will drop down and catch.Just try it very carefully and you will see that the cutter should always line up with the center of the bar.The whole bar will twist if the cutter is off the center line,very dangerous.........be careful when you try this......take care.....
