Grizzly Scroll Chuck - New Purchase
Gary Ratajczak
>I had the opportunity to visit the Grizzly store in PA this week as I was passing through. After looking at the Grizzly (Vicmarc copy) four jaw chuck I decided to give one a try. I have no experience with any other chucks, so actual comparison is difficult. I'll be using on a Jet mini. Out of the box, fit and finish looks pretty good for an import. There is a little slop in the jaws, but everything comes together when tightened. I'm going to take a few measurements and pick up a new allen wrench from Reid tool - the supplied wrenches seem a little loose fit for my taste. For $89.00, I thought it was high enough quality to get me started. By the way, they had 44 units in stock for those ready to give one a try. I also picked up the 1" pin jaws for $17.00. Once I get things mounted on the lathe, and run a few pieces, I'll post some pics so everyone can get a closer look.
Re: Grizzly Scroll Chuck - New Purchase
Re: Grizzly Scroll Chuck - New Purchase *LINK*
Gary Ratajczak
>Here's the link
Grizzly Chuck
Clem Wixted
>Thanks, Gary,
I'm considering one also. I'll look for your experience report.
Clem
Does the chuck have a threaded insert?
Clem Wixted
Check the pdf manual at the link
Bill Howatt
>I have one and have talked to some others who have them. I think it is a good chuck. The threaded insert is exactly the same as the vicmarc and will swap between the two as will the jaws. At least on mine. I've heard one report of a the Griz. chuck not working well but that person got good response from Grizzly so it worked out in the end.
It is not the same quality as the vicmarc but I still think it is a good buy. The wrenches that come with it seem cheap but so far none have brocken. The finish isn't as good and there was more slop in the jaws.
I've used mine now for about 4 months or so and it seems to work fine.
Thanks, Bill. I CAN get an additional insert.
Clem Wixted
Ian
>I've been using mine for about 6 months know. agreed its not as fancy as the vic. but neither is the price tag. haven't had any problems with the lathe other than the insert coming loose a couple of times, but that was my stupidiy not a problem with the chuck.
IAN
Ian, Could you expand on...
Clem Wixted
>...your comments about the insert coming loose. This might help others to prevent this from happening to them (me).
Thanks
Clem
Re: Ian, Could you expand on...
>Clem I had an insert on my Vicmarc come loose once when I was trying to remove the chuck from the lathe. These things are right hand thread and it is entirely possible to have it come loose when the insert gets seated really hard against the spindle. One of the nylon washer will prevent this.
Ian
>sorry about that, should have said more.
The chuck comes with a short bar for removal from the spindle, and also comes with a screw for mounting blanks. If you try to spin off a blank that you have turned the outside of without either holding back with the removal bar or loosening the jaws hold on the screw, the chuck has a tendency to come loose, leaving the insert on the spindle.
IAN
