Finish for Aromatic Cedar?
Mark Kauder. Phenix City, AL
>I turned a bowl for a neighbor from a chunk of Aromatic Cedar from her yard. The wood had been laying on the ground for a while, and the sapwood was pretty punky, but I was able to get the bowl turned with a little sapwood contrast on the sides.
My question - do any of you finish Aromatic Cedar? I would like it to retain that great Cedar smell.
Mark
Re: Finish for Aromatic Cedar?
Georg Waldhof
>several things about aromatic cedar:
1) the aroma will fade with time since (if I remember correctly) it is caused by release of disturbed resins in the wood. The smell can/will be absorbed by anything kept in an enclosed area with the wood (like a closet or bookcase) and the closer it is to the wood, the greater the absorbtion of the smell.
2) the aroma can be "reactivated" by lightly sanding the unfinished wood. Be aware that some people can be allergic to the wood. Reputedly, the aroma repels moths.
3) the same resins that cause the aroma make finishing aromatic cedar a little tricky at times. I've had success with laquer, and less success with polyurethane (tends to stay tacky longer). I've also used Tung oil, but have noticed that the tung oil soaks in and starts looking a little blotchy after awhile. Same with stains. Perhaps a good rubdown with naptha would be good, but that also kind of kills the aroma
4) left unfinished, aromatic cedar actually intensifies its color over time. The heartwood gets deeper red-brown (unless you stumble on the purple-red variation) and the sapwood shifts a bit to the yellowish.
I'm sure someone else in the group has more/better information.
Good luck
George
Fog Tanner
>I have quite a bit of aromatic cedar boards,some are over 20 years old. They still have the same smell, which is both good and bad. I am allergic to cedar and I can only stand the smell so long. It might affect your neighbor the same way, so it would be best to find out first. Some people are affected, some mildly and some have no problems at all.
I turn a lot of endgrain boxes, and use Shellawax cream. This is basicly shellac with a wax in it to allow you to finish it on the lathe. I have started using 1 and 2lb cut lemon yellow lately for a different look. On some pieces I have put on some BLO,dried it on the lathe and then the shellac. I have also used Minwax Antique finish and wax for another look. All these finishes pretty much seal the aroma so noone is botheredby them. For some boxes that I made for a friend, that has no problems with the smell, I just sanded the inside down to a fine finish and didn't apply anything.
Good luck in your quest.
Fog
Terry Quiram, Roanoke Illinois
>Mark
I don't know of any finish that will let the smell of the Cedar through. I have finished with BLO, Watco, Lacquer, Poly and Shellac. You can also sand super smooth and Beal Buff.
Terry
Ruth NIles
>Hi Mark,
The cedar pieces I've made were just buffed and left natural. George is right about just a light sanding will release the aroma after time, however you don't want to be getting the bowl back every so often to resand and rebuff nor do you want someone else sanding your finely finished bowl. Guess you can't have both, retention of the aroma and a bowl with a finish so just sand and buff without using the wax wheel (?).
Ruth
JKJ in East TN
>Mark,
There was a recent thread where this was discussed a little.
I generally use only beeswax. It lets the smell come through for a long time. Since turnings are usually thin compared to boards, the smell does diminish much faster but it can be refreshed periodically with a drop of cedar oil.
I dislike the dark effect from oils and other penetrating finishes and don't particularly care for gloss on cedar. I love the softer look I get from beeswax. I posted the picture below once before, but it shows the effect.
Mark Kauder, Phenix City, AL
>Thank you all.
John, that is exactly what I was hoping was a solution.
Mark
David Breth
>Another case where I am super-grateful for this site. I've got a piece of curbside cedar that I've been saving for a rainy day, and I would have tung-oiled it for sure. Now I will beeswax it for sure.
A few weeks ago somebody made a post about ash, and how it turns urine yellow with oil finish. Had that post only been made a few days earlier I wouldn't have a pee bowl on my shelf right now...
JKJ in East TN
>I did forget to mention I use a bit of Renaissance Wax over beeswax (and over most everything else except for high gloss friction polish).
