tool rests...newbies
Keith Tompkins
Keith Tompkins
>Most tool rests, as supplied by the manufacturer, are in need of a bit of TLC, right out of the box.
Most experienced turners ease the back edge (facing the turning) with a file, then sand the surface smooth. If you run your hand across this surface on a new rest, you will find it is fairly sharp!
You would not want to get a finger or two caught between the turning and that sharp edge. Next, polish the surface that the tool rides on.....remove nicks, dings and scratches. A polished rest allows the tool to glide easier.
Then, maintain the polished surface regularly.
Re: tool rests...newbies
>I sharpen the edge on my rest and touch it up with a diamond hone. Set it just below center and slide it against the work with the lathe running really fast. Voil�! Instant cylinder or cone. Great for roughing bowl blanks.
For anyone who took this seriously, NOT! Don't try this at home. You will get hurt and break your tools.
>Oh Barry, I already had visions of cutting the post to my tool rest and mounting it at 45 degrees so i would get a shear cut. Then I read your warning. bummer. I have a curved rest. I was going to sharpen it for interiors.
JKJ in East TN
>I also use a wax on the tool rest. Renaissance Wax works very well for me. Great for the bandsaw table as well.
