We value your privacy.
>In the absence of anchor seal (or equivalent), what could be substituted? I'm going to be given some basswood (allegedly), a 4 foot branch that came down in a storm, but left untreated. I'm thinking to cut some off the ends once I get it, and then apply some because I don't have anchor seal at the moment and kind of have to wait for Christmas to get some. Would tung oil, for example, be a poor man's substitute?
>Another option is some yellow or white wood glue. Just coat the surface. In the long run it is more expensive than anchor seal but in a pinch it does. Work. Canning wax will work also, just melt it carefully in the microwave in a measuring cup and brush it on. Or put it in a pie pan and dip the wood into it. Hope this helps.
Satisfactory end coatings include water-based wax, asphalt-based roofing cement, aluminum paint in a spar-varnish base, and paraffin.
If course, the roofing cement may not be appropriate for your application! If you have a Woodcraft store nearby, they carry the water-based wax emulsion (Anchorseal or equiv.) in 1 gallon jugs. If you belong to a turning club, call around - someone may gladly loan a cup of sealer.
BTW, I agree with the advice to melt paraffin in a double boiler. Set some on fire just once (with a spoon over a candle) and you'll see why!
